How to root Android 4.4 on Onda Tablet ?
Hung
Forum Posts: 13
2014/01/01 - 05:48
Excuse me ! How to root Android 4.4 on Onda Tablet ? I use ROOT_Limpieza_Logo_V3 for traditional root and root is can't acesss for my tablet
badboy1de
2014/01/22 - 11:08
Same Question !
Or is there a Kasty Release for the V975 V3 ?
Jobster
2014/01/23 - 13:16
See topic
http://www.arctablet.com/blog/forum/onda-v972/v975m-root-tools-zip/
Worked for me and might work on other Onda tablets
My Onda: V972_v2 4.4 Kitkat Rom
PrvSAT
Forum Posts: 25
2014/04/07 - 23:02
The link posted from baidu.com does not work, so the entire procedure is useless, unless someone wants to uploads the required files in some other place.
andersonwoo
2016/01/21 - 11:52
You can have a free try of iRoot, which works very well on Android 4.4 device's rooting. And the step by step guide is pretty simple and fast.
1. Download iRoot from its website. (2 versions included)
2. Enable the USB Debugging mode on your tablet.
3. A: Connect your tablet to the Windows PC.
   B: Run iRoot APK on your tablet, rooting without computer.
4. Detect the device via iRoot.
5. After detecting the device, click "Root device".
6. Wait a few seconds. iRoot will root your tablet now.
7. After rooting successfully, your device will restart.
Pay attention to the battery life of your device. It can not be less than 80%.
70 Guest(s)
Devices in use: Desktop (62), Phone (8)
anqilan456
havetoregister
werasler
5256makc
e-victor
vienzo
