Charging cable for Onda V 973
luking
Forum Posts: 26
2015/03/01 - 21:22
Does anyone know where can I buy a Charging cable for Onda V 973?
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2015/03/02 - 10:19
It is just a mini USB cable! Any computer shop will have it! Charger is 5V 2A thats it.Micro_USB_Cable.jpgImage Enlarger
luking
Forum Posts: 26
2015/03/03 - 03:16
OK Thanks. I somehow thought it is a micro USB
pingu123456
Advanced Member
Forum Posts: 103
Thanks Received: 28
2015/03/03 - 08:27
You are right. It is a micro USB and not a mini USB which is a slightly different connector.
YOU probably need to make sure that the cable has a long micro USB connector part if the side of the tablet is curved like my V813. Otherwise more normal (shorter) connectors may not make proper contact.
some examples here
too short
good long connector
Pingu
luking
Forum Posts: 26
2015/03/03 - 12:34
Pingu123456
Awesome, many thanks for explanation and the links.
cheers
luking
Forum Posts: 26
2015/03/19 - 02:09
Just a FYI that I bought following cable and it turned out to be too short
http://www.ebay.ca/itm/351134570260
Getting noodle cable now
pingu123456
Advanced Member
Forum Posts: 103
Thanks Received: 28
2015/03/19 - 09:38
You still need to be careful (or maybe lucky) that you get one with a long connector.
this one looks better but it is hard to tell from the photos
http://www.ebay.co.uk/itm/1M-Micro-USB-Flat-Noodle-Data-Sync-Charger-Cable-for-HTC-LG-Samsung-S3-S4-Note-2-/381196940377
better to search for "usb micro cable long connector"
like this one looks good
http://www.ebay.co.uk/itm/1m-Micro-USB-Data-Charger-Cable-w-8mm-Extra-Long-Connector-for-Android-Tablet-PC-/171720442191?pt=UK_Computing_USB_Cables&hash=item27fb56014f
Pingu
luking
Forum Posts: 26
2015/03/27 - 03:41
Pingu
I ordered another noodle cable which thankfully works but with great difficulty. It has to be pushed hard all the way in and tilted to one side.
I have now ordered the following
http://www.ebay.ca/itm/Long-connector-Micro-USB-Data-Charge-Cable-for-i9100-i9300-N7100-I9220-BLACK-1M-/381194150724?pt=LH_DefaultDomain_0&hash=item58c0f12344
Pingu
Thanks a lot pal. You have been very helpful. I guess what we need is really a micro usb cable with long connector.
Currently Online: jfdc
52 Guest(s)
Devices in use: Desktop (48), Phone (5)
Dante1975
adb
amanita12
mony18
spiik
nikitamaan
