2013/04/26
Thanks for the comment lolxdptrd!
How do I contact Onda about this; on their site onda.cn there's no email adress to find, only tel numbers.
Antelife.com is giving me a hard time on warranty (they do not do anything about this; a $10 coupon of a store I never buy again from), despite the promise they made on a 365 days period of guarantee!
A new battery and an new screen will cost me ~$60 ($24+$34) and an hour of my time.
So, does anybody has a service adres of Onda?!
nice day!
2013/04/26
@vel2000
I learned my lesson and switched to a nexus 7 2013 and a Memopad 102a; the Onda was still used by the kids for games...fully charged exactly 45 min of playtime.
did you tried any warranty action to the reseller or Onda; or is it normal that this crap dies within the year?
2013/04/26
I think I figured out the problem; combination of crappy charger and bad heatflow design. The polymer gel of the battery was heated to often and quick; this caused a buildup of gas. And gas expands... till the tablet says 'crack'. see http://batteryuniversity.com/learn/article/the_li_polymer_battery_substance_or_hype for details on battery architecture.
I bought these cells; 13000mAH http://www.aliexpress.com/item/3-7V-13000mAH-44105186-PLIB-polymer-lithium-ion-battery-Li-ion-battery-for-tablet-pc-ONDA/1675812644.html
I always found the onda charger crappy, with bad contacts and very quickly overheated. the charge also took to short. I cut out one cell (to be replaced) and charge only via a usbport of my pc.
So, my advice; use a more stable (slow) charger to prevent exploding battery cells
Inside of cell is quite neat; stacked layers of lithium-cobalt
2013/02/12
prutserhugh said
@vel2000did you tried any warranty action to the reseller or Onda; or is it normal that this crap dies within the year?
No, the tablet "itself" is crap (chipset and firmware wise), so it wasn't worth the hassle....
I've rarely really used the tablet, just for a little bit of Rom-tinkering.
Eventually, I've simply removed the blown-up battery and the working one (~6 months old) and soldered an USB cable directly to the mainboard.
Use it only as an Internet radio in my workshop now.
The second battery (which was okay, when I removed it) blew up by itself without even charging!
The original Onda charger died within the first three months.
After that, I used my 2A ASUS charger.
I guess, the outside temperature has a large impact on the battery life-time.
30°-35°, as in my case, seems to be to hot for that cheap junk.
2013/05/16
I use now the batterypack from http://www.aliexpress.com/item/3-7V-12000mAH-44105186-4493105-2-polymer-lithium-ion-battery-for-LG-Li-ion-battery-for/1578127291.html
I've noticed that my tablet is not heating up so much now when using, so probably this battery is much better than the original ones
2013/04/26
After twenty emails; I finally got trough their chenglish and managed to get a $50 refund... to repair the tablet myself..
Lessons learned; never by electronics from a chinese manufacturer; compared to the well engineered EU/US the price for a brand on your tablet is worth it!
2013/05/16
Fredo said
I use now the batterypack from http://www.aliexpress.com/item/3-7V-12000mAH-44105186-4493105-2-polymer-lithium-ion-battery-for-LG-Li-ion-battery-for/1578127291.htmlÂ
Hmmm; this battery is also not THE solution : this new battery works after loading for +-2 hours with wifi off in 90% of the working time ...
So I guess that this battery after 1 year will also be completely lost ...
If someone knows a real good battery that fits (and can be ordered from EU easily) for onda v972 please let it know
2013/04/26
Hi jon2000.
bought new battery pack and new screen on aliexpress and claimed $50 from the reseller. Tablet worked fine ever since.
check:
Very easy to replace --> design is very loose and ill proportioned , dis- and re-assembly just takes a few minutes.
good luck
67 Guest(s)
Devices in use: Desktop (60), Phone (7)
chema1971
speedyftp
georgicaa97
kkn
LatifMohammadi
arthurmax01
