Android 4.4 now Avalabile on Onda v972
DigitalWarS
2013/12/27 - 12:00
vel2000 said
DigitalWarS said
Anyone tested it? Is it safe?
Yes, after removing the Chinese crap and replacing the "Onda Launcher" with the Launcher from the 4.2.2 firmwares, it runs smooth.
No mayor issues so far, but rooting is not that easy at the moment.
I am working on it....
I'm also testing it now, seems fine! Runs better than with Kasty or ufficial rom..
Joseph, on stock launcher seems like I don't have the drawer button on home screen or I can't find it...how do you enter app droawer from home?
DigitalWarS
2013/12/27 - 12:04
My post just went to .... !?
Thank you for your feednack, I am also testing it right now and it works fine , however better than Kasty's 4.2.2 or the las ufficial...Even battery is better...
  However, on home screen seems like I don't have the button to access the app drower (or at least I ca't find it). How do you get to drawer from home scfreens?
josephohare007
Forum Posts: 11
2013/12/27 - 12:31
I replaced the stock launcher with Nova launcher and fixed that one but issue...  forgot to log that one...
vel2000
Forum Posts: 61
Thanks Received: 44
2013/12/27 - 13:01
ok, at least I have found a way to root it.
I will do some tests and upload a cleaned ROM later this evening
ATM I am on 3G, so have a little bit patience, until my ADSL comes back to life
The following users say thank you to vel2000 for this useful post:
DigitalWarS
DigitalWarS
2013/12/27 - 14:54
Vel, remember the drawer button missing on original launcher! 😉
Hung
Forum Posts: 13
2013/12/27 - 14:56
How to root this firmware 4.4 rc
vel2000
Forum Posts: 61
Thanks Received: 44
2013/12/27 - 15:05
I replaced the, more than childish original Launcher, with a launcher from a 4.2.2 Rom.
screen.jpgImage Enlarger
DigitalWarS
vel2000
Forum Posts: 61
Thanks Received: 44
2013/12/27 - 15:37
iceqube, Jobster, SumoX, DigitalWarS
msav
Forum Posts: 71
Thanks Received: 13
2013/12/28 - 05:59
I too aam having an issue going from 4.4 back to kasty 3.2.1
it gets to the end of flashing and says invalid file and firmware flash failed.
any help would be appretiated.
Update:
I installated the original V972Core4_v3.2_v1.img posted in july  and was able to recover.
DigitalWarS
2013/12/28 - 08:27
vel2000 said
And here we go - 4.4 rooted!
Vel, what did you remove and add?  Is it a safe flash? How is it behaving? Thank you!
oldpainless888
2013/12/28 - 09:29
Can you please tell me how you rooted?
K
vel2000
Forum Posts: 61
Thanks Received: 44
2013/12/28 - 09:54
Are you familiar with Linux, the sunxi-tools and bash scripting?
Seriously, this is not a "one-click" process and even more difficult with the new 4.4 ROM's
But here is a good starting point
gupta16
2013/12/28 - 13:51
Hi, I have very similar tablet like onda v972 but it have another driver for touch , touchscreen is inverted ,but work ( after flash kitkat firmware for onda v972 ) . I try change script.bin , bootloader.img , boot.img , config.fex but without effect . Please help ! One question , this firmware with root is based on demo or official kitkat for onda v972 ? Today is available official kitkat .
iceqube
Forum Posts: 14
Thanks Received: 5
2013/12/28 - 14:16
gupta16 said One question , this firmware with root is based on demo or official kitkat for onda v972 ? Today is available official kitkat .
http://onda.cn/Tablet/ProductInfo.aspx?ProductId=239&d=down
Update: In 2013-12-28
Description:
1. system upgrades to version Android4.4.2
2. Ang initiator optimization and upgrading
3. desktop menu added screenshots under multiple functions such as
4. optimize CPU performance
5. optimize system memory
6. optimize power consumption
7. optimize the touch response is faster, more fluid operation
8. optimization of multi-tasking ability
9. added Google cloud print function
Note:
1, firmware packages containing brush tutorial, and Brush tool, use the brush machine for desktops;
2, brushing machines are at risk, please please read the tutorial before you brush;
3, this is a beta version of firmware, V1 only versions of models;
4, the query version number, please look at the back of the fuselage SN code, 9th place;
Onda V813
geetsce
2013/12/28 - 14:39
What is this 'brushing machines', may that be a machine translation of the Chinese term for 'rooted device'?
75 Guest(s)
Devices in use: Desktop (64), Phone (11)
jomama
biggfafa
himikus300483
CyberByte
printerr724
KarlCharlson
