2013/05/01
http://pan.baidu.com/s/1kTjtYrP
Everybody now to use the demo version to see the issues , bugs
2013/09/12
v972_v1_v4.4demo.rar works on onda v972 v2
i tried it on onda v973 v2 but didnt work.
next i ll try
v972_v3_v4.4demo.zip on onda v973 v2
will let u know if works.
download links below
http://pan.baidu.com/share/home?uk=389436537&view=share#category/type=0
2013/11/24
murataka said
v972_v1_v4.4demo.rar works on onda v972 v2i tried it on onda v973 v2 but didnt work.
next i ll try
Each model has its own firmware developed for itself.
You can not mix all like to make a fruit salad
When will release the firmware for wave v973 v2 then you can install it without trouble
2013/12/25
Hi mates, (this i my first post.. so "Hi")
did anybody know if there is a way to downgrade back from 4.4 beta to normal stock rom?
No, TWRP is not working..Â
its unable to mount the needed devices (data, emmc, system... and so on), so I can't just install an new cfw.
PhoenixSuite does not work also.. it always just asks to make shure that the file is valid and so on...
I think the only way back to cfw is through a downgraded stock rom..
Any ideas?
2013/11/24
dende said
Hi mates, (this i my first post.. so "Hi")did anybody know if there is a way to downgrade back from 4.4 beta to normal stock rom?
Any ideas?
I confirm that PhoenixSuite it works, it must work!
Also I have tried the 4.4 beta rom, and then went back to rom kasty.
Maybe something wrong in your procedure ...
Load new ROM via PhoenixSuit for wave V972:
Follow the steps as in the video ...
2013/12/25
Hi, thanks for reply..
PhoenixSuite is working if I try to flash 4.4 img (i've done it about 10 times for now..) but if I want to downgrade to another rom it just throws errors.
I've tried flashing out of Android (the device is shown correctly then reboots, then Phoenix shows the error)
I've even tried switching off the tab, holding Home-button, pressing 10x the power button.. (Phoenig recognizes that the tab is connected and tries to flash.. which leads to error..)
Have u also tried to flash cfw with twrp?
2013/12/25
Yes I have selected Yes..
I've also deleted all drivers and reinstalled them, i've tried 1.06 and 1.08 (several times)
I've also downloaded 3.3.1 3.2.1 and 1.35 several times (Checksums have always been correct)
I've switched the USB port..
nothing worked.. I'm running out of ideas...
2013/12/25
No, I don't have any SD-Card inserted..
In fact that it's important for u.. When I tried to flash 4.4 I have to confirm 2 times YES.
When I try to flash any other FW it's only one confirmation and I get the error..
Burn firmaware failed!
Please ensure the firmware file is valid and device work out correctly!
On issues upgrading from 4.2.2 v3.3.1:
tested results: Â Only issue is with HDMI output to 1080p TV - needed a reboot to enable sound (sometimes) plus, only supports up to 720p, no so much an issue with 4K viewing.. but VLC viewing in the 720p... Â would be good to resolve this.Â
1. removed all Chinese apps - if you can't delete you can disable.  - no  issues at the mo.
2. replaced stock Launcher with Nova ( just  that I like this  Launcher  format).
all in all looking good  - it would great to see a Root version as I need SMB server for home sharing.
73 Guest(s)
Devices in use: Desktop (59), Phone (13), Tablet (1)
XSTR
aldi_2003
dtcinfly
Ultraprost
feasycom
THEDRACk
