wireless connectivity
gjs999
2013/07/23 - 00:03
have updated to latest firmware but have noticed that my wireless connection keeps dropping off -was OK before update and my other tablet has no problems . Anyone got any suggestions .
smfelton
2013/07/23 - 21:15
Same problem here, tried Cyanogen and Wifi seemed much better but apps were hanging, so flashed back to latest stock rooted. Hopefully will be fixed in an update soon as this is the only issue I have with this tablet.
jihaine
Forum Posts: 17
2013/07/24 - 11:47
no problem with the custom firmware V3.2 (2013-06-21)
the only worry is that the wifi disables occasionally on wake up, but performances and range are normal.
HeinzOtto1
2013/08/12 - 20:42
There is no issue with 3.2.1 custom firmware. It works great. only negative is still the high consumption of the battery. After about 3h the full charged battery was empty. Used browser and PDF reader only.
Alban1
Forum Posts: 14
Thanks Received: 4
2013/08/13 - 14:12
I found that the WiFi signal kept dropping off on my Onda V972 v1 3.2.1
I then discovered that it returned to normal after a reboot but un-tick the fast boot option.  Don't know if it will work on yours but may be worth a try.
38 Guest(s)
Devices in use: Desktop (33), Phone (5)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
