1 new boot logoÂ2. new Onda desktopÂ
3. underlying SDK upgrades, system stability and compatibility enhancementsÂ
4.Miracast function optimizationÂ
5. system comes with software to increase multi-language supportÂ
6. fixes known software issuesÂ
7 Set – stored under the new built-in disk total capacity display Note: 1, the firmware package containing Brush tutorial and Brush tool, use desktop computers Brush; 2, Brush risk, please before Brush carefully read the tutorial; 3, the V2 firmware version applies only to models; 4, check the version number, see the back of the fuselage SN code 9,10 bit;
Linux Kernel:Â Linux version 3.3.0 (onda@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #2 SMP PREEMPT Sat Nov 16 10:11:51 UTC 2013
Android system:Â onda/fiber_ondam785q6V1/fiber-ondam785q6V1:4.2.2/JDQ39/20131116:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.75 (free version)
- removed Onda new launcher
- optional Team Win Recovery Project (TWRP) easy install package
- New! kernel modules (USB GPS, Xbox/PS3 gamepads, OpenVPN,…) compiled by Christian Troy, thank you. See our guide for XBOX 360 gamepad support
cardvr, nadim86, wini If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Not much I can do about it I'm afraid. The problem was probably here in the original firmware from Onda... and I don't have a V819mini tablet to try to fix the problem.
CHeers.
The weird thing is I haven't done any modification that would cause problem with the accelerometer.
I will double check if I can find possible reasons.
2013/02/12
Hi
First let me
The weird thing is I haven't done any modification that would cause problem with the accelerometer.I will double check if I can find possible reasons.
Hi
Thanks for great work....I downloaded and installed the latest for this tablet and the auto rotation does not work anymore. I then went to http://www.gadget-rumours.com/firmware-2/onda-tablets-firmware-ver-3-3-1-released/ and downloaded there V3.3.1 version and the rotation does now work also the icons etc. on this download are all different so it looks as if there is another version which may have been relaesed to fix the bug....downside all chines apps are back....
Thanks Frank
2013/12/03
romasz said
HiÂ
Will try different launcher but maybe the V819 is different From V818....still does not explain why Onda version is Ok but The kasty one stops the rotation....
Cheers
As I said already, I am using this ROM on my v819mini and Auto-Rotation is working in my cases. More than that, this ROM has better performance than the original one. You have no choice but to try to understand what is going wrong. I suggest to check if Android is even getting a rotation interrupt. Try to catch the logs with "logcat" while rotating your tablet. You will need to know how to work with adb for this. Anyway, send us the log. My log for your reference below:
Rotate to landscape
--------- beginning of /dev/log/system
I/InputReader( 2183): Reconfiguring input devices. changes=0x00000004
I/InputReader( 2183): Device reconfigured: id=1, name='gt9xx', size 768x1024, orientation 1, mode 1, display id 0
I/ActivityManager( 2183): Config changes=1480 {1.0 ?mcc?mnc en_GB ldltr sw768dpw1024dp h695dp 160dpi xlrg land finger -keyb/v/h -nav/h s.47}
D/by hero ( 2874): ro.ddr512m = false
Rotate back to normal
I/InputReader( 2183): Device reconfigured: id=1, name='gt9xx', size 768x1024, orientation 0, mode 1, display id 0
I/ActivityManager( 2183): Config changes=1480 {1.0 ?mcc?mnc en_GB ldltr sw768dpw768dp h951dp 160dpi xlrg port finger -keyb/v/h -nav/h s.50}
58 Guest(s)
Devices in use: Desktop (48), Phone (10)
cutierogue
