Linux Kernel:Â Linux version 3.3.0 (Nurmuhammad@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Fri Oct 18 08:23:02 UTC 2013
Android system:Â onda/fiber_ondam785q6V1/fiber-ondam785q6V1:4.2.2/JDQ39/20131018:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.65 (free version)
- removed Chinese girl boot logos
- New! kernel modules (USB GPS, Xbox/PS3 gamepads, OpenVPN,…) compiled by Christian Troy, thank you. See our guide for XBOX 360 gamepad support.Â
After flashing the tablet, a Setup Wizard may appear on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should now be displayed.
cardvr, xcode If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Sorry about that guys, I don't have the tablet so I can't be sure the firmware works perfect.
The longer first boot is probably normal, but the launcher not starting is an issue I will have a look at.
2013/11/11
The only reason I installed this firmware, is becuz its rooted.
The problems I discovered (so far) are: no auto rotation (annoying), no launcher (so installed a custom launcher). Or is there a fix already, about the auto rotation?
Hopefully these will be fixed soon.
But I still like this ROM. Tnx!
I am checking to fix the firmware, but it's not the easiest thing, not having the actual tablet to test my modifications. I'll post when a new build is ready for testing.
2013/05/24
Onda released new firmware
V819mini_v3.3.1_v1
http://www.onda.cn/Tablet/ProductInfo.aspx?ProductId=257&d=down
Is it possible to make new custom firmware based on it? I have a tablet and I can test it.
I should have a look tonight.
cardvr If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
I'm late here and few other Onda firmwares to finish.Â
2013/09/17
Good evening,are you planing to make the custom rom of the latest firmware v3.3.1.i have the tablet for a week and ihave problem with the battery,it last 2.5 hours on 3d epiccitadel loop.5 hour web use.is normal?onda claims 8 to 10 hours video.is this normal or i have battery problem/softer optimization?i m in thought to go back to v3.2.2 to test.
Currently Online: andikafox
56 Guest(s)
Devices in use: Desktop (50), Phone (6), Tablet (1)
XSTR
aldi_2003
dtcinfly
Ultraprost
feasycom
THEDRACk
