1 new boot logoÂ2. new Onda desktopÂ
3. underlying SDK upgrades, system stability and compatibility enhancementsÂ
4.Miracast function optimizationÂ
5. system comes with software to increase multi-language supportÂ
6. fixes known software issuesÂ
7 Set – stored under the new built-in disk total capacity display Note: 1, the firmware package containing Brush tutorial and Brush tool, use desktop computers Brush; 2, Brush risk, please before Brush carefully read the tutorial; 3, the V2 firmware version applies only to models; 4, check the version number, see the back of the fuselage SN code 9,10 bit;
Linux Kernel:Â Linux version 3.3.0 (onda@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Sat Nov 16 06:25:26 UTC 2013
Android system:Â onda/fiber_ondam784q6/fiber-ondam784q6:4.2.2/JDQ39/20131116:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.75 (free version)
- removed Onda new launcher
- optional Team Win Recovery Project (TWRP) easy install package
- New! kernel modules (USB GPS, Xbox/PS3 gamepads, OpenVPN,…) compiled by Christian Troy, thank you. See our guide for XBOX 360 gamepad support
alexil, jihaine, cterraza, jlbahi, notthatgeeky, plc_error If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/07/24
Nice work admin.
I installed yesterday and all works fine, very smooth and fast. Antutu benckmark score is +20000.
This ROM is more efficient than the 3.2.1. I not tested the USB OTG feature yet and the battery life still same than the previous ROM. If i found problems i will inform you.
ssunder, blodnje,
Please make sure your device is a V818 V1, there may be some hardware incompatibility if you are using this firmware on a different V818 version.
I'll see what I can do when time permits.
Rooted custom Kitkat firmware for the V818mini (V2) just posted:
73 Guest(s)
Devices in use: Desktop (67), Phone (6)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
