Linux Kernel: Â Linux version 3.3.0 (Nurmuhammad@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Fri Aug 9 12:05:48 UTC 2013
Android system:Â onda/fiber_ondam785q6V1/fiber-ondam785q6V1:4.2.2/JDQ39/20130816:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.51 (free version)
Download:Â kasty-onda_v819_mini_v1-422-v322_20130820-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
MindMe, cardvr If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
This firmware is made for the V819, it probably won't work on V818.
We have custom firmwares for the V818 here:Â http://www.arctablet.com/blog/forum/onda-v818/
Thanks for your support, please let us know who it goes when you receive your V819Â
2013/02/13
hey everyone,
i'll begin this post with a little notice that i did have v972 tablet (software starting from version 1.2 till latest 3.2), but it turned out to be a little heavy and bulky to me. i left this one for my parents, so they could have a multimedia station with games, youtube and music =)Â
I was thinking of buying a 8-inch tablet and couldn't choose between v812v813 and v818. Another day i took glance on onda's website and discovered they actually had released a new v819 model, i thought "this is it!!" and ordered it immediately. It came to me yesterday night, and here are my first impressions.
IT IS AMAZING! way better than v972 by feelings, appearance, size and weight!!! I didn't have possibility to work on ipad mini, but the android version of it (i mean here v819) is just superb!!Â
Screen:Â (8.5 out of 10) The only tiny con here (as well as in v972) was the screen, i mean i had tiny tiny glares at the edges there in 972 and in this one, but overall you will never notice it if watching photos and videos. The brightness of v819 is outstanding comparing to "retina" display of v972. I hope v973's have a better brightness capacity.Â
Battery (9 out of 10) is much better than v972, even though the capacity is twice as less (8000mAh in v972 against 3800 in v819). I think that's not because of screen size and dpi, but also less RAM and, i believe a31s processor is well optimized comparing to simple a31. For instance with fresh kasty ROM from arctablet my v972 lasted a bit less than 2 hours, but here i watched plentyfull of videos and did work on it hard for 4 hours and still have 33% battery left.
I don't want to talk about Antutu and other benchmarks, as i don't believe 20000+ points have smth to do with reality in this rom, but overall the tablet is smooth and speedy.Â
The dimensions of this one are exact to those of ipad-mini, except v819 is wider for 5mm. however the Belkin's case for ipad-mini fits almost ideally here (it coveres volume buttons and 3.5mm jack hole, but that's not a big deal, u can always unfold it)!
the difference between v818 and v819 is in abscence of home-button on the side ov v819's. That means it has ONLY power button (and volume control tho), that brought about issues with flashing the tablet properly (u remember, u have to turn off the tablet, press and hold home-button, stick the micro-usb in and click desparately the power button until the flashing starts). Here i turned off the tablet, pressed and hold VOLUME DOWN button and followed the same operations as i wrote above. nothing's sophisticated =) maybe i did it in wrong way, but that worked for me.
it hanged up only once for me without any following issues when i tried to install and work with uTorrent. I think i will download movies in other way, lol =) Not sure if i will overclock the CPU for more than 1088 GHz, i don't see any big deal about it.
Overall this baby is very very very impressive! Hope u will have the same experience as i had (except hang-up lol ).
2013/02/13
time - battery test during non-stop device usage (played TH Poker similar to poker sites in usa where US NJ poker sites such as http://www.njpokersites.net/ can be tricky to play using those apps, Worms; serfed; used various apps etc):
00 min : Charged
00-30 min : 95%
30-60 min: 90%
60-90 min: 85 %
90-120min: 80 %
120-150min: 74%
150-180min: 67%
and going...Â
how to make a screenshot on these tablets? Its unbelievable
2013/10/23
Hi everyone,
I'm new here. I'm with some doubts about onda V819... I want give him to my girlfriend but I really need to have it "almost" perfectly working. With Kasty ROM tablet has gyroscope, 3G dongles working ? Are google apps all working fine ? Mindme what do you think about tablet's case, is it metal? Are there issues with it?
Kasty ROM remove the chineses boot imgs ?
Sorry about all these questions but I need to prepare her gift.
Thanks to everyone for your work
2013/02/13
xcode said
Hi everyone,I'm new here. I'm with some doubts about onda V819... I want give him to my girlfriend but I really need to have it "almost" perfectly working. With Kasty ROM tablet has gyroscope, 3G dongles working ? Are google apps all working fine ? Mindme what do you think about tablet's case, is it metal? Are there issues with it?
Hey, xcode,Â
As for my experience - this is really "almost" ideal tablet. It is much better that its much more expensive analogs by its 1. screen, 2. battery (it is enough to go on minimal brightness for 7-8 hours of active using (2-3days with no use at all)) , 3. Speed (worms armageddon and runners work nicely =) . and Kasty Rom takes the real shit out of it!!! This tablet has a wellmade gyroscope, however i didn't test it with 3G dongle.. i'm gonna test microHDMI pretty soon - will post about it =) I said "almost" because i sometimes really lack bluetooth, but that's not critical - =))
I did try to connect USB-flashdrive and USB dongle for Mouse (via USB-female - microUSB-male cable) and it worked pretty well.
I didn't try all google apps obviously, but i would say that everything ran correctly for me.Â
It is 10000% worth its money ONLY if your particular tablet would be finely made without any defects.
PS: as for my previous experience, the tablet NEEDS(!!!) protective case! The alluminium is fragile here
2013/02/13
xcode said
Thank you fr the fast reply!What do you think about onda's case ? Is it possible to change the boot chinese images ?
almost any case, that fits to ipad mini - also fits this tablet.
I didn't by Onda's case, as i bought it almost very first - they didn't have cases for v819 there then, not sure if they sell it right away =)
Bro! By using this ROM you get rid of 90% of chinese apps (i have only 2 left - some help-app and browser)
but it's worth it.Â
2013/10/23
Seems so good man! I do want to surprise my girlfriend with this tablet. So tell me about the touch display... Is it smooth ? Tablet came with the last firmware right ? Basically everything is working fine without forces closes apps or something like that ?
Thank you so much for all your information!
Cheers
2013/05/24
Installed this firmware and instantly discovered the problem with auto-rotation. It rotates but in opposite direction Re-installing the firmware didn't help.
Downloaded new chinese firmware V819mini_v3.3.01_v1.rar from here
and all works as it should.
Maybe you can make new firmware based on this latest chinese version?
56 Guest(s)
Devices in use: Desktop (49), Phone (7)
