Linux Kernel: Â Linux version 3.3.0 (Nurmuhammad@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Sat Jul 27 06:23:37 UTC 2013
Android system:Â onda/fiber_ondam784q6/fiber-ondam784q6:4.2.2/JDQ39/20130727:eng/opinions-on-teclast-p90hdst-key
2, optimize system performanceÂ
3, optimize tablet standby timeÂ
4, optimize HDMI TV output function, support 1080P input and Full ZoomÂ
5, amended Chi reader does not recognize the local disk compatibility issuesÂ
6, amended in google play find Youku, and other parts of the application tuxiuxiu questionÂ
7, the amendment 4K player, vertical screen gestures invalid under the volume problem
- root with latest SuperSU 1.51 (free version)
Download:Â kasty-onda_v818_mini_v1-422-v321_20130730-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
_Javi_, ru.Egor, HeinzOtto1, huyprotb12, cterraza, shebani, alexil, jlbahi, ronchang, wildfir If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/07/05
Hello Admin,
don't know why but I lost MIRACAST wireless display feature. The feature is always off and I can't turn it on. There is even not the option to turn it on or off. It seems to be that I lost some important files on the SD card as I played with TWRP. Also on the drop off menue the connection icon dissapeared.
Are you able to help and let me know which files are needed in which directory to get it back.
Thanks so much!
2013/07/24
help me admin,
i having troubles with this new firmware, after i flash it the battery drains too fast and the battery icon shows that the battery is charging while it is unplugged.Â
I reflash it to older version 3.2 dated 2013/07/02, and still the problem. The tablet never enters to stand by just poweroff the backlight but all the android processes keep running and consuming processor and memory.
I choose the format mode everytime flashing the tablet.
2013/08/15
Thanks for admin , its really nice work.
I flashed the rom Onda V812 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2.1 (2013-07-29) in V812,  every thing work well, arctools work well too. its can define the model and display the TWRP recovery for all model include v818. and i can download and install TWRP recovery and reboot in recovery mode and its work very well.
and I also flashed Onda V818mini (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2.1 (2013-07-30)Â rom in v818, but arcools can't define the model and didn't display recovery so can not install TWRP recovery.
Do have any comment of this situation
thanks Â
The list of packages displayed in ArcTools for TWRP recoveries is based on the detected devices.
There is probably a problem with the Onda V818 being properly detected, I'll have a look.
2013/08/15
The list of packages displayed in ArcTools for TWRP recoveries is based on the detected devices.There is probably a problem with the Onda V818 being properly detected, I'll have a look.
I copied the build.prop on v812 and replace it on v818, then arctools works well and can display the the recovery, then I download and install WTRP for 818, and reboot into recovery, the result is as showing in attachment pic. as shown there to icons can't display : Wipe & Reboot. so it's big problem to exit recovery mode. can't reboot device to system. its always reboot to WTRP.
I think the problem is not the size, the main problem is the direction of recovery, on v812 the recovery is horizontal and on v818 is vertical. Â Â
2013/08/05
Can confirm the problem with TRWP showing incorrectly on v818 mini.
By the way i found a way to reboot in TRWP on v818 mini by going into advanced and there is option to change something related to folders, access rights, something like that, after that change i got prompted with reboot option.
Also for some reason i cant get now better scores in antutu then 12400 for some reason, when having cpu set to 1200Mhz, how i did score 21000 previously is mystery, unless having set lower cpu frequency to 1044Â Mhz was better then having 1200Â Mhz. It could be due to wrong governor, but it was set to fantasy(s) or performance via setCPU.
88 Guest(s)
Devices in use: Desktop (67), Phone (20), Tablet (1)
kevbez
xxxdddd
xxxddd
Kaydc__
jessicapeterson
Riki111
