[ ROM ] Onda V818 mini (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.0 (2013-05-22)
votsirh
31
2013/06/12 - 16:53
Thanks for your reply. I cannot say i am happy with this one and probably i will try this one later and hope everything will be okay after all i dont need a non-working tablet :) I will update you how it went.
andysmoore
32
2013/06/12 - 17:14
Hi, what about the hdmi out option?
Is that anything to do with the firmware?
Does it need enabling Some how?
votsirh
33
2013/06/16 - 00:05
Hello All,
I cannot enter Flash Mode on my Onda v818. I am following the steps descibed and nothing's happening. I have the PhonexSuite loaded my firmware then .. turn of the tablet, holding home button, connecting the tablet then i start pressing power button for 10-20 seconds and nothing's happening. I tried with USB debugging ON and off (btw. what should it be ? on or off ?) Do i need some special PC drivers for that or the Phoneix already installed them ?
Please help :) Are there any special options which i have to set before that, like the USB mode, i can see 3 there: Media Device (MTP), Camera (PTP) and USB Large Storage ?
Ah and one more thing, when the tablet is ON i can see it connected to PheonixSuite ..
Thank you.
arielp
34
2013/06/16 - 03:37
votsirh said
Hello All,
Thank you.
You're doing it wrong..
Do like this:
While tablet is powered OFF
Hold Home button,
while holding home, insert USB cable (which already connected to PC)
then while still holding home button, repeatedly press Power button 10times, with 0.5 second interval between press..
then it shold be detected.
try again.
if you closely follow this tutorial http://www.arctablet.com/blog/featured/phoenixsuit-flashing-tutorial-onda-v972-v812-allwinner-a31-tablets/
you should go no wrong
Motorola XOOM - 4.2.2 My Android by dreamcwli
Chuwi V88 Mini - Oma RK3188 4.2.2
Onda V818 - Arctablet Custom 4.2.2
nick789uk
Forum Posts: 45
35
2013/06/16 - 03:48
HI just a thought are you using the usb lead that came with the tablet as it may not work with another lead.
Nick
votsirh
36
2013/06/16 - 12:33
hi,
thanks for ur replay. I am using the usb that came with the tablet and also i  following the same guide, even watched the video and i repeated all stepa more than 10 times with different options usb debugging off and on. Is PhoenixSuite 1.0.5 the older version can flash this tablet , it may be something wrong with it ? And do i have to turn on the usb debugging ?
EDIT: Okay, i tried everything from begging but on my laptop instead of the desktop i've used before and it worked from the first time. I believe there was a problem with the installed driver on my desktop.
nick789uk
Forum Posts: 45
37
2013/06/22 - 16:22
Hi is anyone aware of a problem with  Phoenix Suite and windows 8 as when I have connected my tab to the computer running windows 8 it will not find it but using windows 7 and the same tab v818 will find it straight away.
Ps Using  Phoenix Suite 1.6
df186
Forum Posts: 16
38
2013/06/23 - 18:16
Hello Admin,
I just noticed that this version of the ROM does not include VPN Settings.. Was that removed for a specific reason? I use it to watch Hulu...
Please let me know..
thanks
df
Thanks Received: 3171
39
2013/06/23 - 20:28
No changes have been made in regards to VPN settings, the original firmware from the manufacturer we used to build the custom firmware probably had no VPN support. If Onda doesn't not fix it in the future, it may be possible to build a kernel module (was recently done on a PIPO M6 RK3188 tablet)
We'll see what can be done, when time permits.
gjs999
40
2013/06/26 - 14:37
new code on onda site - wonder what the improvements really are
nick789uk
Forum Posts: 45
41
2013/06/26 - 16:48
hope a rooted version will come out soon
gjs999
42
2013/06/27 - 20:40
thought they were rooted from factory ?
smfelton
43
2013/06/28 - 01:13
This new ROM is superb, really fast no lag, I downloaded latest from Onda (v3.2)
http://pan.baidu.com/share/link?shareid=1399772674&uk=389436537
flashed it then rooted it using this guide, worked perfectly.
http://www.arctablet.com/blog/featured/root-onda-v812-onda-v972-and-allwinner-a31-based-tablets/
andysmoore
44
2013/06/28 - 01:32
Does it still include all the chinky apps?
if so will wait for a cfw!
arielp
45
2013/06/28 - 01:40
how about browsing experience?
i have the Chuwi v88, its a night and day difference between onda and chuwi, its not apple to apple though, but chuwi is alot faster in term of browsing experience.
onda just simply lag...
76 Guest(s)
Devices in use: Desktop (70), Phone (5), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
