Here is a new Android 4.2.2 Jelly Bean update for the Onda V818 (hardware V1) tablet, it's still called V3.0 but has a more recent system and kernel than previous release.
Firmware build information
Linux Kernel: Linux version 3.3.0 (xufangduo@VServer) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #6 SMP PREEMPT Wed May 22 14:20:55 CST 2013
Android system: onda/fiber_ondam784q6/fiber-ondam784q6:4.2.2/JDQ39/20130522:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.30 (free version)
Download: kasty-onda_v818_mini_V1-422-v30_20130522-rooted4.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Onda V818 mini to test it.
wildfir, jihaine, df186, jlbahi, palexr, dikkedam, Bruce Wu, msev, votsirh If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/05/10
Admin,
Thanks for this ROM and firmware update.. this is even smoother than the previous 4.2.2
initially i had issues with ROM slowdowns especially with internet use.. while i was downloading tablet slowed to a crawl.. but now with this new one.. its so much better.. thanks so much!!!
2013/05/16
Good morning guys.
I have the doubt if you could update the file ROM V818mini_v3.0_v1.img putting the SD and flash it from recovery, no need to connect to PC and use the program PhoenixSuite.
I ask this because on a mobile Huawei G300've done well, also using a file with a. Img to update.
A greeting
Updates in "update.zip" format could be updated this way, but for .img files such as we have here, you need to use PhoenixSuit as for other Allwinner A31 based devices.
jlbahi If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/04/16
Thanks for this. Just a further question about .IMG updates could we use Odin?
If I understand right, Odin is made for Samsung devices, which is a different platform then Onda tablets, so it's pretty sure it won't work here.
2013/04/16
Thanks admin. Well I flashed it using Phoenixsuit and all went well. The machine definitely feels smoother than before. There is certainly no lag, internet browsers open up very quickly, wifi is stable.
It truely is a great little device now (without all the Chinese cutesey vapourware). Antutu gave 12116.
Very happy.
I had a first look without much success so far, I'll give it another shot soon.
2013/05/11
If you are reffering to my request for bluetooth...Maybe you could take a look into Christian Troy's rom's, look here: http://www.slatedroid.com/topic/65290-rom-cyanogenmod-10-for-allwinner-a31-devices-now-with-hdmi-and-usb-bluetooth-support/
He implemented support for external bluetooths and cp210x among other stuff..
When I recently asked him about how he did it he answered "must be built with a boardconfig.mk parameter to enable bluetooth".. Something like that, if that means anything to you.
Again thank you for investing your time and skills into developing awesome stuff for us, making our devices better!
Thanks!
2013/05/15
Hi admin, the 4.2.2 have changed the primary storage from previous 2gb to now 1gb space only, can you change it back to 2gb or even more in future rom update? Thank you.
By the way, my Onda keep restarting, but can't enter system, press power button to force off won't work, just keep restarting, anybody can help? Thank you.
2013/05/19
egorain said
Hi admin, the 4.2.2 have changed the primary storage from previous 2gb to now 1gb space only, can you change it back to 2gb or even more in future rom update? Thank you.By the way, my Onda keep restarting, but can't enter system, press power button to force off won't work, just keep restarting, anybody can help? Thank you.
have you try reflashing the tablet ?
and make sure choose the format mode everytime flashing the tablet.
i found this latest firmware indeed faster than before, aside from only 1gb ram, now the performance is acceptable, and usable for daily...
The following users say thank you to arielp for this useful post:
egorainMotorola XOOM - 4.2.2 My Android by dreamcwli
Chuwi V88 Mini - Oma RK3188 4.2.2
Onda V818 - Arctablet Custom 4.2.2
2013/05/27
Hi guys! first of all thank you for the work you do!
i have an Onda v818 mini (A31S quad core), i’ve tried to flash it and the format dialogue box appeared, i started the format, it was all fine before the usb cable fell out of the port on the tablet and everything shut down. after this i failed to initiate the flsh mode back again, gave it a few attempts but the tablet just stays power off and doesn’t react at all. What can i possibly try to do?
thanks in advance!
57 Guest(s)
Devices in use: Desktop (46), Phone (11)
cutierogue
