Finally, Onda has published the final version of their Android 4.2.2 Jelly Bean firmware for their Onda V818 (hardware V1) tablet.
The stock Onda V3.0 firmware is expected to correct some issues from the previous Android 4.2.2 beta (Youtube videos, top right notification, system Force closes)
Our custom firmware modifications will be limited to a few fixes, Chinese apps clean up.Â
Firmware build information
Linux Kernel: Â Linux version 3.3.0 (xufangduo@VServer) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #3 SMP PREEMPT Wed May 15 09:25:28 CST 2013
Android system:Â onda/fiber_ondam784q6/fiber-ondam784q6:4.2.2/JDQ39/20130515:eng/opinions-on-teclast-p90hdst-keys
Download:Â kasty-onda_v818_mini-422-v30-rooted.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Onda V818 mini to test it.
jihaine, jobrima, ande2, josemanu72, jlbahi, wildfir, ru.Egor, palexr If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/04/25
ande2 said
Seems that 4.2 didn´t help the sluggish internet browsing. Maybe the 1GB RAM is just too little.Should have gone for the 813...
I don't think that 1gb RAM is too little. My old Cube single core with custom 4.1.1. have 1gb too and it's very faster on internet browsing.
I should have gone for the 812 or 813 too or rockship 3188 tablet (like Cube U33GTmini)Â
2013/04/25
ande2 said
It is weird that everything else runs "smoothly", downloading, installing etc is good but then internet browsing is just making the experience terrible.Â
you're right.
I tested the flow of my internet connection.
with my PC 14050 kbps
with the browser of the tablet : the flow is not steady but average 4230 kbps
with the application speedtest on the tablet : 11399 kbps regular flow.
the difference between the tests is huge. with the browser, it's terrible!
do you really think it is necessary to install 4.2 ?
2013/04/25
jobrima said :
Can you change the security WiFi to wep and test again with speedtest please?
I've always used to set security wifi on wep.
Well, i've flashed firmware with "format upgrade mode" (not "normal upgrade mode" as recommanded) and it seems to get better.
I'll publish is the same, but browsing is better. I'll publish browser et speedtest later
2013/05/10
jihaine said
I agree.. Browsing is better.. however, i did notice now that downloading an app is super slow.. and as its downloading, the whole tablet slows down.. it picks up again after downloading has ended.. but during download super slow.. anyone notice that too? I also chose "Format Upgrade Mode"
50 Guest(s)
Devices in use: Desktop (42), Phone (8)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
