Here is a custom firmware based on Onda V818 mini official firmware 2.0 (2013-04-08)
Build information
Linux Kernel: Â Linux version 3.3.0 (user14@ExdroidM) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #31 SMP PREEMPT Tue Apr 2 14:03:49 CST 2013
Android system:Â onda/fiber_ondam784q6/fiber-ondam784q6:4.1.1/MASTER/20130402:user/opinions-on-teclast-p90hdst-keys
- added ArcTools for easy ClockworkMod Recovery (CWM) installation, see details here
 - added older version of Youtube application, don't upgrade Youtube, newest version do not work ! (thanks msav)
We need your support to continue building and improving our firmwares, please consider making a donation if you appreciate our work. | ![]() |
Download:Â kasty-onda_v818_mini-41-v20-rooted3.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Onda V818 mini to test it.
jlbahi If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/04/16
Thanks for that!Â
There ae a couple of things I don't really understand though....
Arctools. I've looked to download Gapps, it goes through a download sequence and intalls, but it doesn't seem to actually do it. When I reboot and look in the app tray nothing has changed, no Gmail, Maps, Chrome...
Also, I can't find anyway of installing CMW or TWRP? Are the options simply not there yet?
It is probably because I don't understand what i am doing but any help would be gratefully received.
palexr,
You shouldn't use Android Market / Google play store install feature in ArcTools, it won't work on Onda tablets as it's designed for other tablets.
CWM/TWRP install (see tutorial here) isn't enabled yet on the Onda V818, that's why you don't see the CWM / TWRP items in the list of packages in ArcTools, they will be enabled at a later time.
2013/04/16
Hi, just to update, I changed the DPI to 160 (from the native 213) which replicates the larger tablets and I can say that Chrome seems to be much faster. Not sure why that would be but it definitely seems to be.
The interface looks better to too, the toolbar layout is much more like AOSP with the pull up tab at the bottom right. A definite improvement on the phablet layout for me - and smoother.
Use another usb cable, and also the usb ports from the back of the pc unit, this does not apply on laptops
2013/05/10
Build information
__________________________________________________________
 Yo dude.. this is pretty good.. thanks for this.. as one of the other guys stated that it is a little laggy.. but I installed Apex launcher.. and removed default launcher via titanium backup. I also installed SuperCharger found over at XDA Developers and now this thing flies!!!!Â
keep it coming!!!
BTW, You should post this stuff on XDA Developers website.. I was just over there and there are a ton of people that want developers for Onda tablets.. you will also probably get help from the other DEV's too. just a thought!
2013/05/11
Nice to hear that it went well, I might try and flash it as well although it would be my first try and i'm kind of intimidated of it...
Btw guys, does the tablet need to be rooted to allow debugging of application install using adb or is there some other way?
I'm having some problems with one app I'd like to install on the tablet. I got the .apk directly from the developer, since I couldnt get it from Google play, aparently quite a lot of apps aren't "compatible".
When I try to install it I just get -> "X App not installed" and a button "Done"...The app is opensource so if someone could take a look and make it compatible I would be very glad ..Or if someone could try it on their own tablet and just give me the debug output.
Is there a workaround for the non-compatible apps?
Sorry for all the questions!
Regards!
57 Guest(s)
