2013/02/07
TWRP based on lastest 2.4.4.0 for Onda V812 by ankar84
Download: in that post in attachments
Differences between TWRP and CWM Recovery
- Graphical user interface with full touch control.
- Batch patches (up to 10p in the queue).
- Customizable backup/restore. You can choose which partitions to backup/restore if you want to use compression and generate md5-sum set their own names backup and delete unwanted right from recovery
- Displays the time (time zone adjusted separately), battery.
- Saving settings of the recovery on microSD-card.
- Built in Terminal Emulator.
- The ability to connect the two cards to the computer as a USB-carriers.
- Built-in file manager, with copy, move, delete, rename, change permissions.
- A detailed log file.
- Theming support.
TWRP based on latest stable version 2.4.4.0
Internal and External memory are mounted properly.
Internal memory installed in the /sdcard
External Memory installed in the /external_sd
You can store backups on a Internal and External memory as well.
External card is automatically mounted
The following users say thank you to ankar84 for this useful post:
admin, HAVESOV, shebani, fred64TWRP installation for the Onda V812/V813 should be available for installation in ArcTools.
2013/03/20
i can download and boot into the version of twrp given in arctools but the resolution is wrong and I can't see all of the buttons - sorry I am a bit of an android newbie (but keen to learn)
I tried to load the specific v812 twrp zip version using goomanager but it aborts out (my target is to install the cyanogenmod custom rom zip but that keeps crashing too and twrp was suggested) this has already cost me 1 32gb micro sd card that has become fatally corrupted.
The wrong resolution problem is because I haven't yet configured ArcTools to get the proper version for the V812/V813, this should be fixed soon.
ankar84 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
The package for Onda V812 and similar tablets is now available in an ArcTools package for easy installation.
dr_rog, ankar84 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/02/07
romasato said
Hey - do you know if there will be a version of ClockworkMod Recovery for Onda v818? I am very interested! Especially for ability to make nandroid backups and restore them.Â
Or let me know if there is already one and where I can find it!
Thank you!:)
I don't know about CWM, but for nandroid baclup and restore you always can try that TWRP, because screen resolution is same as Onda V812.
2013/05/16
ankar84 said
romasato said
Hey - do you know if there will be a version of ClockworkMod Recovery for Onda v818? I am very interested! Especially for ability to make nandroid backups and restore them.Or let me know if there is already one and where I can find it!
Thank you!:)
Tried on my v818 and don't work...maybe install procedure (via adb) is not ok, I dont't know, just learning while trying to install TWRP+CM10 from slslatedroid.
Regards.
2013/07/23
Hi, I´m new with android and in this forum.
I have installed and reebot with TWRP in my Onda V812, I see the graphical screen, but the touch screen is not functioning. The power button shows a image of a lock with "TWRP" and it says "swipe to unlock" but nowhere on the screen works the touch.Â
What should I do?
Which TWRP have you installed, is it a recovery made for the V812 ?
Fabian Fiorito, huyprotb12 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
66 Guest(s)
Devices in use: Desktop (64), Phone (2)
