[ ROM ] Onda V812 (V1/V2/V3/V4 hardware) Android 4.4.2 KitKat root custom firmware V4.4
Thanks Received: 3177
46
2015/01/30 - 17:40
Hello rob14,
Does this happen when the tablet is powered from a charger ?
rob14
Binangonan Rizal Philippines
Forum Posts: 42
47
2015/02/06 - 18:52
hello admin,
same even powered by charger and without powered charger what do you think the problem or main reason for this issue? pls you help me thanks
I can do all things thru Christ who strengthens me
"phil. 4:13"
humpff
france
48
2015/02/08 - 16:23
pingu123456 said
Hi humpf,
I think it is very important that the battery needs to be well charged up before trying to reflash....
Is it possible that that is part of the problem?
I am happy to do French or English but English is the forum language and I am not French ;-)
There is a French section if you prefer/want to talk there....let me know  - c'est comme tu veux
http://www.arctablet.com/blog/forum/french/
à+
Pingu
hello Pingu
Sorry i was not in a network reachable area for a while.
thanks for your suggestions i will try again this same afternoon, even if i was nearly certain i had a fully charged battery... i wonder if the use of twrp has'nt destroyed the access to the inner tablet... i was intenting to chat with somebody on a twrp chat, the only answer was "sorry we do not support onda tablet and will never"...!!! so nice !!!
my tablet was off since my last post and i let the battery go thru complete discharge. Now i am recharging again to make sure, before doing a new trial.
i will come and edit this post to give you more infos about what's going on even if i am very pessimistic...
thanks again take care see you soon
humpf
La prochaine étape sera l'intégration neuronale : sera-t-elle opensource ?
pingu123456
Advanced Member
Forum Posts: 103
Thanks Received: 28
49
2015/02/08 - 22:36
Hi Humpf,
I have TWRP on my V813 and now I am running Cyanogenmod 11 which is working very well. I am no expert but I can't see how even a corrupt TWRP should stop the tablet being reflashed in Phoenix suite.
Make sure that you are trying to flash the correct version of the software for your hardware version. There are two versions, I think.
Version for hardware 1,2,3 and 4 here from the 1st post of this thread:
http://www.arctablet.com/utils/download.php?server=www&file=/firmware/Onda/Onda_V812/kasty-onda_v812_v1-442-v44-rooted0.zip&p1=1423431147&p2=5b3c63f23bc35079abc98ca6e7de85af04ee9f56&p3=64687
good luck
Pingu
winatci
50
2015/03/10 - 00:35
4.4 is beautiful smooth but i have some serious issues say android system read-only so i cant use openvpn and i cant see storage on pc how to remount system to rw please help
eagleed
51
2015/03/27 - 10:48
Hi. Have been trying to download but it stops around half way. Have used three devices and two networks with the same result. Is this file still available? Thank you.
rob14
Forum Posts: 42
52
2015/04/27 - 17:36
hi guys i noticed that my battery is already dead and it almost broke my LCD because battery is already blotted where can i buy battery for onda V812? or maybe higher capacity 4500mah please help thanks!
"phil. 4:13"
zein
53
2015/05/17 - 22:50
try to remove sdcard and reboot ... i had this issue and it worked !! (والحمد لله)
teoc20 said
Please help me
After installation went ok . But I reboot and does not want to boot, the screen is black.
Mr. JO
54
2015/08/27 - 17:45
Here is latest Android 4.4.2 KitKat update for the Onda V812 (V1/V2/V3/V4 hardware)  based on newest Onda firmware release version 4.4
(V812 Core4_v4.4_v1.rar / V812 Core4_v4.4_v1.img)
Firmware build information:
Linux Kernel:  Linux version 3.3.0 (linghuihua@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #4 SMP PREEMPT Fri Dec 27 05:28:54 UTC 2013
Android system: onda/fiber_onda809q9/fiber-onda809q9:4.4.2/KOT49H/20131227:eng/opinions-on-teclast-p90hdst-keys
ro.reversion.aw_sdk_tag=exdroid4.4_r1.2-a31-v4.4
  • root with latest SuperSU 1.94 (free version)
  • system default setup English
  • added Google Experience Launcher (GEL) in addition to Onda stock launcher
Download: kasty-onda_v812_v1-442-v44-rooted0.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an Onda V812 tablet to test the custom firmware.
please help...newbie...i can't download the file, it keeps corrupting, can you give another link please? thank you very much
eagleed
55
2015/08/27 - 21:21
The posted link is broken. Please post a link that works. Thank you.
TOXTAS
56
2015/09/01 - 19:12
Hi, same problem for me.
57
2015/09/01 - 19:41
The file is correct on the server, I'm checking for a download issue, will keep you posted.
eagleed
58
2015/09/09 - 13:43
Still not downloading. Is there another way we can get the file?
59
2015/09/10 - 00:49
The failing download problem should be fixed now, I have posted some details about the issue here.
You may retry your download.
eagleed
60
2015/09/10 - 07:20
Thank you sir. I finished the download earlier. I was just getting post when I received your email. Thanks a lot.
Cheers!!
199 Guest(s)
Devices in use: Desktop (186), Phone (13)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
