[ ROM ] Onda V812 (V1/V2/V3/V4 hardware) Android 4.4.2 KitKat root custom firmware V4.4
rob14
Binangonan Rizal Philippines
Forum Posts: 42
31
2014/09/19 - 21:31
still no updates so sad :(
I can do all things thru Christ who strengthens me
"phil. 4:13"
rob14
Forum Posts: 42
32
2014/09/27 - 14:31
still no update :(
"phil. 4:13"
joshdigit
33
2014/11/11 - 15:17
Can you make Android 4.4.2 KitKat update for the Onda V801 Quad Core based on newest Onda firmware release version 4.4?
geo1201
34
2014/12/03 - 23:07
Not sure whats wrong with this ROM and my tablet but they just don't like each other. I have a V1 and I've flashed lots of your previous ROMs with no problems, but when I try this one I just get a black screen with the backlight on.
I re-downloaded the ROM again thinking something went wrong there, but it still does the same thing.
I then downloaded the latest official Onda ROM, which this is based on, and it works fine.
Does anyone have any ideas what might be causing this?
binhujorda
35
2014/12/11 - 21:36
Hello friends ,
What is the latest firmware for TABLET ONDA V813 ? (original or custom)
Very Thanks
Fabio
gareem
36
2014/12/11 - 22:38
Archos 80 Platinium works well with this rom, too.
pingu123456
Advanced Member
Forum Posts: 103
Thanks Received: 28
37
2014/12/12 - 18:35
binhujorda said
Hello friends ,
Very Thanks
Fabio
The last/latest custom Kasty rom is here, I think,
http://www.arctablet.com/blog/forum/onda-v812/rom-onda-v813-v1-hardware-android-4-2-2-jelly-bean-root-custom-firmware-v3-3-1-2013-11-21/
The latest stock ROM from Onda should be available from the link on their website but it does not seem to be functioning now.
http://onda.cn/Tablet/ProductInfo.aspx?ProductId=245 (third tab along)
I do have all the roms - both Stock roms and Kasty - here. If you need one, I can upload it somewhere for you.
I really did not like the last Onda stock Rom - Kitkat 4.4 .
The various Kasty Custom roms are good.
At the moment I use Cyanogenmod 10.2 which I have found to be the best for me. Cyanogen 11 is also available but I found it to be less reponsive than 10.2.
Make sure that you do not use roms for the V813s which is a different tablet with different hardware.
best regards
Pingu
rahdoo
38
2014/12/13 - 18:37
hy.i have a problem .i have a tablet onda v812 ( in my country allview 2 speed quad (rebranded) ) i try to instal 4.4.2 works but after finish instal when started the touch not work :( how can i fix it?or tell me a rom working on my tablet.pleas help.thx
pingu123456
Advanced Member
Forum Posts: 103
Thanks Received: 28
39
2014/12/14 - 11:47
This 4.4.2 Rom is for hardware version 1/2/3/4
http://www.arctablet.com/blog/downloads/firmware/Onda/Onda_V812/kasty-onda_v812_v1-442-v44-rooted0.zip
Youtr tablet may have hardware version 5 for which there is only a 4.2.2 custom rom available.
http://www.arctablet.com/blog/downloads/firmware/Onda/Onda_V812/kasty-onda_v812_v5-422-v321_20130729-rooted0.zip
you could try to flash this to see if the touchscreen works.
Pingu
nitram19751
40
2015/01/09 - 22:41
ive made the update with the files from here. everything works fine.
but i have one problem as some others here. i cant see widgets after i install new programms.
have anybody a solution how to solve this???
And do you think, that there will be another update for onda v812???
thank you very much.
humpff
france
41
2015/01/24 - 15:39
hello
i have been running arctablet version of 4.4.2 on my V812 for about a year and yersterday i went to do an update of twrp wich was proposed by the app
after update,  twrp started automaticaly, and as i was not able to understand what to use it for, i choosed "reboot"... BAD IDEA !
since then, the v812 (V1) is not working anymore, and trying to start in recovery (home for 4 sec, then home+start button) gives only a vague backlight and no display at all !!!
after trying to access the tablet via phoenix suite (no recognition of the device) i cannot think of anything to get my tablet back to life, so any help will be very welcome
thanks in advance,
humpff
La prochaine étape sera l'intégration neuronale : sera-t-elle opensource ?
pingu123456
Advanced Member
Forum Posts: 103
Thanks Received: 28
42
2015/01/25 - 13:24
bonjour humpff,
You need to make sure that the power is fully off just before attaching the USB cable to the computer.
If Phoenix Suite is ready with the chosen image to flash, I am pretty sure it will recognise the tablet and that the tablet will reflash properly.
If you are not sure if the power is completely off, hold in the power button for approximately 10 seconds - until the screen goes completely dark. This is easier to see in a dark room.
Bon chance,
Pingu
humpff
france
43
2015/01/25 - 23:45
hi pingu
thanks a lot for taking the time to answer.
Actually i was certain tablet was off before to connect to pc
once usb cable connected, the tablet backlight went on...since, phoenix suite was not able to see the tablet.
i am waiting for the battery to be totally down, then i will do some trials again i will let you know.
à propos tu préfères parler en français ?
bien cordialement,
humpf
pingu123456
Advanced Member
Forum Posts: 103
Thanks Received: 28
44
2015/01/27 - 14:59
Hi humpf,
I think it is very important that the battery needs to be well charged up before trying to reflash....
Is it possible that that is part of the problem?
I am happy to do French or English but English is the forum language and I am not French ;-)
There is a French section if you prefer/want to talk there....let me know  - c'est comme tu veux
http://www.arctablet.com/blog/forum/french/
à+
Pingu
rob14
Forum Posts: 42
45
2015/01/30 - 17:38
I have problem with my Onda v812.  Tab everytime. I use my tab for a couple of minutes battery drain fast and screen will blink for a few seconds and willl automatic shutdown
Anyone have Idea what is the problem of my tab? Thanks!
"phil. 4:13"
205 Guest(s)
Devices in use: Desktop (191), Phone (14)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
