[ ROM ] Onda V812 (V1/V2/V3/V4 hardware) Android 4.4.2 KitKat root custom firmware V4.4
hotroderinn
2014/04/23 - 10:53
arieid1 said
Wifi problem:
in wifi, advanced, keep wifi on during sleep : never. solved the problem
This.
And yes, the widgets doesn't appear anywhere
cucucuchu
2014/04/23 - 11:32
I have the same problem whith my two OndaV812 devices. I think it must be because the based onda firmware does not have this property
KUKUKU-CHU
Thanks Received: 3177
2014/04/23 - 11:40
It's quite likely an issue from the manufacturer's firmware.
There is no change in our custom firmware regarding the way the widgets work.
primod808, rob14
rob14
Binangonan Rizal Philippines
Forum Posts: 42
2014/04/24 - 19:45
nice this is what I'm waiting for! but I will wait for another firmware release from onda. I need 95% firmware bug free. :) but I'm very happy because onda keep our tab on track! even they have a lot of newer tab released.... :)
I can do all things thru Christ who strengthens me
"phil. 4:13"
primod808
2014/04/26 - 04:39
Thanks for the response at least I know what the problem is. I aso found a few more bugs I could not download Google plus app or any keyboard replacement apps from Google play. But I think its the KitKat firmware that is the problem since I could download these apps before KitKat.
Thanks again.
maxlay007
2014/04/27 - 15:37
Thank you.
lidel
2014/04/30 - 01:57
thank you. when i'm updating an app, after several seconds the tablet freezes, the touchscreen doesn't work and if i push the stand by button, i cannot use the tablet and i'm forced to turn off and 95 on 100  an app is updating, i have this issue! i had with the stock firmware and with this version. if the wifi is disabled, i have a nice user experience. anybody has the same problem?
ps: sorry for my english. i hope you can understand what i have written
cucucuchu
2014/04/30 - 07:12
Hello, I have the same problem. Uncheck the automatic update in all the application and make it manually. Updating one by one I solve the problem.
Bye
The following users say thank you to cucucuchu for this useful post:
Xadiez, lidel
KUKUKU-CHU
rob14
Forum Posts: 42
2014/05/02 - 08:15
after updating I'm so please with the performance of my Onda V812 tab but the problem is................. some of widgets are now gone, every time i turn off my tab and then turn on again. some of shortcut icon is gone and i need to put it back again in home screen.... battery drain fast.................
I'm looking forward in next update! 🙂
"phil. 4:13"
rob14
Forum Posts: 42
2014/05/24 - 16:33
this firmware has lots of bug :( I'm very disappointed......... when you turned off your tab and turn in on again icon will randomly scattered in your home screen even you organized the icon specially in Onda launcher....... battery drain fast...... when I updating some apps or downloading once your tab automatically sleep while installing thru market your tab will not turn on again display is blackscreen only and you need to press hard the on/off button........ i wish onda will release new update
"phil. 4:13"
Sebastiaan Smit
2014/06/08 - 12:33
Here is latest Android 4.4.2 KitKat update for the Onda V812 (V1/V2/V3/V4 hardware)  based on newest Onda firmware release version 4.4
Thank you for the Kitkat update, Admin! :-)
Over all, this version is running smoothly. It seems like my Onda V812 is faster now, but I did not measure that. My Onda did not have the reported issues with WiFi and camera. But I ran into a few other problems. Whatever I try, I can't login to my provider's e-mail account. I can read my mail via webmail, but not via IMAP.
Some apps that used to run on 4.2.2 don't work anymore. Amongst them are Google+ and some games.
Any suggestion on how to solve the problem with IMAP and the compatibility issues is appreciated. Otherwise, I'll be patiently waiting for an update with these issues solved. Apart from the issues, the Kitkat update is good.
edit 2014-06-12: It turns out that my tablet freezes very often. I'm going to downgrade. :-(
lidel
2014/06/22 - 01:11
Bye
unluckily, even setting manually the apps update, the tablet often frezees and i'm forced to turn off the tablet. this situation really sucks. is it so hard to create a fully working firmware? they should stop invading market with new devices and workin to offer better firmware, i have paid this crap with "fully working" and i want what i deserve, not a sort of beta product . i also use a pipo m9 and android sucks in that tablet, too, (made last update), personally i'll not buy another device with android. i don't understand the utility of having more power ( 388cpu, 94 gpu cores, 100 MB of ram, etc.) supported by an embarassing software. i have a cheap nokia 630 ( quad core, 512MB ram) and the difference between certain 8 core android smartphones\ this nokia that runs very fast and very stable  is the perfect explanation from a bad optimized system and a real good one.
rob14
Forum Posts: 42
2014/07/21 - 20:24
any updates about this tab? i'm still waiting!
"phil. 4:13"
2014/07/22 - 10:58
It has been a while Onda hasn't made updates to their firmware, I am afraid they probably won't produce any new firmware for their Allwinner A31 devices. Confused
As for our custom firmware, there are probably a few small improvements we could add, I'll see what can be done in August.
rob14, iceqube
rob14
Forum Posts: 42
2014/07/22 - 17:05
Admin
so sad.... but I'm happy hear that their will be updates this coming august :) looking forward...... :)
GOD bless :)
"phil. 4:13"
206 Guest(s)
Devices in use: Desktop (192), Phone (14)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
