[ ROM ] Onda V812 (V1/V2/V3/V4 hardware) Android 4.4.2 KitKat root custom firmware V4.4
Thanks Received: 3177
2014/04/07 - 21:21
Here is latest Android 4.4.2 KitKat update for the Onda V812 (V1/V2/V3/V4 hardware)  based on newest Onda firmware release version 4.4
(V812 Core4_v4.4_v1.rar / V812 Core4_v4.4_v1.img)
Firmware build information:
Linux Kernel:  Linux version 3.3.0 (linghuihua@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #4 SMP PREEMPT Fri Dec 27 05:28:54 UTC 2013
Android system: onda/fiber_onda809q9/fiber-onda809q9:4.4.2/KOT49H/20131227:eng/opinions-on-teclast-p90hdst-keys
ro.reversion.aw_sdk_tag=exdroid4.4_r1.2-a31-v4.4
  • root with latest SuperSU 1.94 (free version)
  • system default setup English
  • added Google Experience Launcher (GEL) in addition to Onda stock launcher
  • New! kernel modules (USB GPS, Xbox/PS3 gamepads, OpenVPN,…) compiled by Christian Troy, thank you. See our guide for XBOX 360 gamepad support
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an Onda V812 tablet to test the custom firmware.
oviso, psk, Xadiez, stringer44, danbo055, lolxdptrd, frdcg, ModURbox, cucucuchu, engryahya, primod808, rob14, sunyi5411, oblaarggag, PAg, Sebastiaan Smit, jjas30, colwilard, kkr1669, matrix_pr
lolxdptrd
Forum Posts: 24
Thanks Received: 6
2014/04/08 - 19:05
I've just installed it on my V812 V4 no problem.
Very smooth, no real noticeable difference with previous 3.3.1 version except for the lower antutu  score (around 12400) which in fact is not lower, it's accurate, previous version score was due to a tweak with the GPU that made it score much higher on antutu, but general performance were the same.
No noticeable problem with wifi, all my favorite apps were downloaded fast.
Camera is ok, no force close on gallery, or I haven't been able to reproduce it.
So far so good.
The following users say thank you to lolxdptrd for this useful post:
primod808, tabletfan
ModURbox
2014/04/09 - 00:51
Thanks for the great update, I'm got very fond of the Google now launcher on my Samsung Galaxy S2 so this is the icing on the cake.  Did have some issues so re-flashed my V812 (v4) and that cured the problems now having similar buttery smooth experiences as lolxdptrd.
Onda v812 v4 tablet running Kasty Onda v812 4.4x rooted
Samsung Galaxy S2 running slimkat 4.4x
hotroderinn
2014/04/10 - 12:37
Wifi doesn't connect automatically after the tablet was in stand by for a while.
The rest so far so good.
No chinesse model in boot screen! Biggest improvement! X)
ModURbox
2014/04/10 - 13:33
Haven't been running WiFi during standby but I will give it a go see if it acts up. What I will report is an incredible increase in game and video applications.
I stream with Xbmc Frodo on my last ROM 4.22 Kasty Xbmc didn't run so good lagging badly during menu transitions now it's a speed demon. In gaming I'll refer to two games I've played
Shine runners and Dead Trigger.  Shine runners runs great but hard to see any improvement it's a different story with DT it's incredibly fast at low settings so fast in fact that I thought I was playing a different game. The real improvement was evident when pushed the quality settings to max the game was still very playable which wasn't the case before with 4.22.
The last thing of note is Chrome browser I had gave up on it because it was terribly slow though that may have been dev issues. For now with this KK ROM it's going great. Happy days on my Onda v812 v4
The following users say thank you to ModURbox for this useful post:
arieid1
2014/04/12 - 16:03
Same problem with wifi on wake up.
Otherwise a great update, thanks
cucucuchu
2014/04/13 - 16:58
Muchas gracias por tu trabajo.
After upgrade the firmware I have an issue, after a quick boot the menu is clean and the applications list is clean too, there aren't any access to the applications.
If I change to onda boot loader or I make a normal boot the applications icons reappear and all works OK.
Another question. There aren't widgets in this firmware? I can't use, for example, the calendar widget because don't appear in the widget list.
Thanks for your attention and sorry for my English.
KUKUKU-CHU
ModURbox
2014/04/13 - 18:07
This only happened when I had made a system change the device needs a full re-boot for changes to take :-)
A update on the wi-fi sleep issue which I appear to not to be effected by. My device has went to sleep four times in the past 40 hours and I've no problem with getting wi-fi access when coming out of sleep.
Screenshot_2014-04-13-16-52-09.pngImage Enlarger
arieid1
2014/04/15 - 17:26
Wifi problem:
in wifi, advanced, keep wifi on during sleep : never. solved the problem
The following users say thank you to arieid1 for this useful post:
befa34
teoc20
2014/04/15 - 23:15
Please help me
After installation went ok . But I reboot and does not want to boot, the screen is black.
cucucuchu
2014/04/15 - 23:32
Teoc20:
Push the power button twelve or more seconds to ensure the tablet is off
push and hold the home button and push the power button. Hold the two buttons about twenty or thirty seconds and the tablet must start in recovery mode.
Select reboot and... We see
KUKUKU-CHU
teoc20
2014/04/16 - 08:48
No work screen remains black.
I can not use  Phoenix Suite to return to the old firmeware
cucucuchu
2014/04/18 - 11:53
Definitively tested. I have two onda v812 and after install this firmware I have the same problem: after a quick boot, when I used the google launcher, the screen is clean, all the icons disappear, and in the application list the icons disappear too and can't launch any application. I need make a normal boot and the icons reappear and all work OK.
I haven't any problem with the Wi-Fi in the two tablets
My best regards
KUKUKU-CHU
wizwarez
2014/04/21 - 03:32
Installed this firmware last Friday and I'd like to say that I am falling in love with my v812 for the second time.  It is in the best state since I bought it.  Speed is very good and wifi is stable.  No improvement is the battery utilization but I'm OK with that.  No issues encountered so far.
Thank you very much for preparing and sharing the firmware.
primod808
2014/04/23 - 10:05
i justd installed 4.4 kitkat and it runs great very smooth, thank you for this.  i only have one issue and was wondering if anyone else has experienced any issues with adding or finding widgets.  i know it kitkat you have to go into settings and security and check of enable widgets, but even after that i do not see the widgets list.  on 4.3 i had no problems but with the same widgets i had then i cannot find them on kitkat.  has anyone had this problem?
thanks again for a great rom!
56 Guest(s)
Devices in use: Desktop (46), Phone (10)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
