[ ROM ] Onda V812 (V1/V2/V3/V4 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.3.1 (2013-11-21)
scarybuzz
2014/01/15 - 07:35
downloading now, the link is working fine with me, download speed is good too
installed, fluid and very good rom, currently downloading kitkat from onda
update:
this rom (v3.3.1) is much better compared with stock onda kitkat, antutu score 20883 on v3.3.1 while scored 12411 on kitkat
battery consumption on kitkat 2 hours while 6 hours on v3.3.1, just sharing my experience (tested by playing continuous music)
rob14
Binangonan Rizal Philippines
Forum Posts: 42
2014/02/12 - 07:35
That's why I'm waiting for 4.4.2 custom rom! patient is a virtue. :)
please admin...... make a 4.4.2 custom rom.....
I can do all things thru Christ who strengthens me
"phil. 4:13"
rob14
Forum Posts: 42
2014/02/12 - 07:40
good thing about this custom rom is very stable, battery life is good and no chinesse Girl on start up boot!
"phil. 4:13"
Xadiez
2014/02/13 - 11:19
I also want a kitkat custom ROM please.
It is the best ROM I have used.
rob14
Forum Posts: 42
2014/04/05 - 19:49
still no update :(
"phil. 4:13"
Thanks Received: 3170
2014/04/05 - 20:29
It should be posted this week-end, I still have a few tweaks to finish.
iceqube
iceqube
Forum Posts: 14
Thanks Received: 5
2014/04/05 - 20:37
http://www.androidpolice.com/2014/03/28/first-android-4-4-3-details-come-to-light-here-is-what-you-should-expect-to-see-fixed/
With the introduction out of the way, let's take a look at the list of fixes, prioritized by me in order of importance. The list may not be complete, but this is what we've been told so far:
  • frequent data connection dropout fix
  • mm-qcamera-daemon crash and optimization fixes
  • camera focus in regular and HDR modes fixes
  • Power Manager display wakelock fix
  • multiple Bluetooth fixes
  • fix for a random reboot
  • app shortcuts sometimes got removed from launcher after update
  • USB debugging security fix
  • app shortcuts security fix
  • Wi-Fi auto-connect fix
  • other camera fixes
  • MMS, Email/Exchange, Calendar, People/Dialer/Contacts, DSP, IPv6, VPN fixes
  • stuck in activation screen fix
  • missed call LED fix
  • subtitle fixes
  • data usage graph fix
  • Internet telephony fix
  • FCC compliance fix
  • miscellaneous fixes
Should be out within some weeks, hope Onda will soon release updated roms! :)
Onda V813
2014/04/07 - 16:42
Sorry for the delay, I am almost done with the Kitkat V812 (V1) custom firmware. Based on my tests on a V975, the only bug left is a small issue with the virtual keyboard update, it should be fixed shortly.
danbo055, frdcg
2014/04/07 - 21:25
teoc20
2014/04/16 - 16:08
Hai, i have update my tablet  but now I have problems with my camera, both cannot be used
Please help !
2014/04/16 - 16:23
teoc20,
It is possible that the hardware version for your tablet does not match the one for this firmware which is compatible for V1/V2/V3/V4 hardware. So if you have a V5 model you should try the firmware made for this version.
raddub14
2014/06/21 - 13:45
hello, I tried to install this custom firmware on an Allview Alldro Speed 2 Quad (Allwinner A31, specs here: http://www.allview.ro/produse/tablete-pc/lista-tablete-pc/2-speed-quad/specificatii/ ), and I believed that this model coincides with Onda v812, but I've made a huge mistake...
Now, after flashing the tablet is booting in rom but the touchscreen does not work !!
I don't know what to do.. because I can't install a TWRP to try a different CM rom from Slatedroid, and even the stock recovery preinstalled with the custom rom doesn't have a working touchscreen.
..and I even don't know the original tablet of this brand allview !!
What can I do to make my tablet work again?
2014/06/21 - 20:23
raddub14,
In current situation, maybe it's worth trying (at your own risk) other Onda firmwares, like V812 (V5) or other V81X models.
If you want to restore the stock firmware, you should request it to the vendor that sold you the tablet or to the manufacturer.
raddub14
2014/06/21 - 21:35
Well, I tried that all day long... So far I tried Onda v811 v3, Onda v812 v1.. but I believe that model is not going to work. Then I tried Onda v801s v5, the touch was working but it was reversed, also the image was not clear (was.. negative colored), now I keep trying with Onda v801s and so far I tested the v3.3.1 and v2.0, but none of them had a working touchscreen.
Is there any chance to find out the correct model with the correct version of firmware?
Also I can't request to the vendor because I will lose the warranty and a will also have to pay for repair, nor the manufacturer because Allview is a pretty stupid romanian company and will do nothing for their customers.
yo_5h0rty
2014/12/19 - 22:26
salut radu,
so, did you repaired your tablet??
i have exactly the same problem, but I tried only v812 firmwares.
please contact me if you repaired your tablet.
thanks
140 Guest(s)
Devices in use: Desktop (136), Phone (4)
printerr724
KarlCharlson
Ser1111
tjkjrukgesibuq
erervervr
lukluk91
