1 new boot logoÂ2. new Onda desktopÂ
3. underlying SDK upgrades, system stability and compatibility enhancementsÂ
4.Miracast function optimizationÂ
5. system comes with software to increase multi-language supportÂ
6. fixes known software issuesÂ
7 Set – stored under the new built-in disk total capacity display Note: 1, the firmware package containing Brush tutorial and Brush tool, use desktop computers Brush; 2, Brush risk, please before Brush carefully read the tutorial; 3, the V2 firmware version applies only to models; 4, check the version number, see the back of the fuselage SN code 9,10 bit;
Linux Kernel: Linux version 3.3.0 (onda@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 – Linaro GCC 2012.02) ) #2 SMP PREEMPT Sat Nov 16 10:11:51 UTC 2013
Android system:Â onda/fiber_ondam785q6V1/fiber-ondam785q6V1:4.2.2/JDQ39/20131116:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.80 (free version)
- removed Onda new launcher
- optional Team Win Recovery Project (TWRP) easy install package
- New! kernel modules (USB GPS, Xbox/PS3 gamepads, OpenVPN,…) compiled by Christian Troy, thank you. See our guide for XBOX 360 gamepad support
gusy81, dewacabul, psk, rob14, primod808, adit31, damnshah, datoxxl, superkafer, scarybuzz, cardvr, guran1999 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/03/01
2013/05/27
Dear Admin,
Thank you for the great ROM...i just flashed it and everything seems to be working smoothly so far...
quick question, i noticed the Christian Troy kernel allows for bluetooth via USB. I bought myself a cheap dongle just to try it out but it doesnt seem to work. Would you have any suggestions to kick start this or should i check at the source website?
thank you once again
2013/12/26
rob14 said
how about the battery life? is their improvement in battery life?
Compliments for the fast working tablet ( again)...
However same problems over here regarding the battery life, shocked how fast the battery drains.
Any heard about a solution for this, or do i have set an older firmware version.
Regards,
TheoldVic
2013/04/03
I bought a new battery, because stock one was draining in less than 1 hour. New one lasts 2-4 (depending on stress). Here is the link http://www.aliexpress.com/item/In-stock-3766125-3-7V-4500mah-Lithium-polymer-Battery-with-protection-board-For-iPad-3-Onda/738233419.html
P.S. Also try turning off mobile data (Settings -> Wireless & Networks -> More... -> Mobile Networks), it's not necessary for this tablet and may extend battery life.
2013/08/17
I do not know about 812 but 2-4 hours sounds pretty short, running nonstop games/benchmarks?
For longer duration next time I suggest one with more mAh like http://www.aliexpress.com/store/product/tablets-Batteries-large-capacity-SANYO-3-7V-polymer-lithium-battery-5500mAh-for-Onda-V801-v811-v801/631097_1554304889.html
Onda V813
2013/04/03
4 hours playing continuously for example "Plants vs Zombies 2"... 🙂Â
Good battery suggestion, it's new in stock I think, wasn't out when I made the order (2 months ago). With that one tablet will last longer of course.
94 Guest(s)
Devices in use: Desktop (82), Phone (12)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
