To my knowledge, the only way to flash the tablet is to use PhoenixSuit which working only on PC/Windows.
You can try to run it in a Virtual PC emulator on your Mac, it may work if the USB port virtualization with this software works fine with Windows/PhoenixSuit and the tablet. If you try, please report how it goes.
2013/07/16
I didn't get it to work in the Virtual PC - (Windows Parallels). PhoenixSuit recongized it when I first plugged it in and put it in flash mode. The Mac asked if the USB device should be sent to the Mac or Virtual PC, I selected Virtual PC and to always remember ... but once I hit 'Update' in PhoenixSuit I heard the PC 'dong' and lost the USB connection.
I was using Parallels 5 ... a newer version may help ... but I doubt it.
2013/07/14
I have installed this v3.2 on my new 813, all seems to be working well.
I upgraded from stock ROM via v3.0 and I found none would operate my old E169 3g wireless dongle.
Is here any fix for this or am I up for a new dongle? If a new dongle required which are compatible?
There may be a problem with frequencies as I am in Australia.
 Edit
The V813 appears to recognise the dongle as some APN's are listed but my provider is a sub agent of one of the APN's. A sear of mobile networks returns 'error on searching' message.
2013/05/30
Hello! I did clear install (wipe) of the kasty firmware 3.2 (after trying the original 3.2 ) in order to solve the problem with write permission on the SD card. It is pretty nice that the chinese applications are removed and it is working fluently. The problem that encountered was with USB drives, containing more that one filesystem/partition - these are not recognized at all. So I had to upgrade again the original one, without wiping. That removed arctools, and root access, but restored recognition of all USB drives. Then tried to disable chinese applications (becouse no option to uninstall appears) and USB drive was again not recognized.
So I report this as bug. It seems that any of the chinese applications (although they look like links to chinese market sites) does something with USB driver
2013/12/28
Hello, maybe anyone got any ideas? Tried to update V813V1 firmware and device just got bricked... While updating Phoenix software gave error, can't tell witch for sure and then when i connected device next time system just writes unknown device and Phoenix cant' see tablet.. Tried reinstalling phoenix and drivers but nothing helps. Updated firmware several times before and nothing like this happens. Tablet does not react on power button in any way.
Any help would be great!!!
UPDATE: All ok now.. Somehow helped that i plugged in usb while holding tablet power button.
Onda V813
213 Guest(s)
Devices in use: Desktop (202), Phone (11)
