Linux Kernel: Â Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Thu Jul 25 16:28:08 CST 2013
Android system:Â onda/fiber_onda804q9/fiber-onda804q9:4.2.2/JDQ39/20130726:eng/opinions-on-teclast-p90hdst-keys
2, optimize system performanceÂ
3, optimize tablet standby timeÂ
4, optimize HDMI TV output function, support 1080P input and Full ZoomÂ
5, amended Chi reader does not recognize the local disk compatibility issuesÂ
6, amended in google play find Youku, and other parts of the application tuxiuxiu questionÂ
7, the amendment 4K player, vertical screen gestures invalid under the volume problem
- root with latest SuperSU 1.51 (free version)
Download:Â kasty-onda_v813_v1-422-v321_20130729-rooted.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
the tester, adam1991, catfish, tjfosjhp, altf4, pingu123456, obeguin, Crossrock, Malolillo123, iceqube, arrasmith, elbetec, oldfella, gargonat, plisplas If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/06/09
Nice ROM - cures the unresponsive hiccup problem experienced with rooted stock ROM. Also has the video codecs needed for system (Gallery) to play normal mp4 video (on stock ROM needed to play with MX Player)
Still refuses to play using standard (cut down socket) micro HDMI, but OTG USB is fine.
Great Work!
[update]
Strangely, my tablet was not rooted after flashing this ROM and I had to root it again using the normal Allwinner_A31 root flash update method.
Also - the Flash player was not working and I re-installed the previous version and settings from the stock ROM (I had saved this using Titanium).Â
All now seems ok!
2013/05/26
Finally my tablet is like a shot in the AnTuTu test is above z sony xperia, more than 20,000 points, wow ..... many improvements found, my tablet is better than ever, in the previous version the wifi failed me, now everything is fine and seems to fit like a glove this rom.
By pointing something wrong, you may be spending higher battery with this rom and also the images you have when you start the tablet, it would also be perfect when you press the power button not only have the option to turn off , would be very well also have the option to reboot.
Many, thank you very much for this work.
Lo que sabemos es una gota de agua, lo que ignoramos es el oceano.
2013/05/26
altf4 said
gargonat said
Finally my tablet is like a shot in the AnTuTu test is above z sony xperia, more than 20,000 points, wow .....ÂIt´s because this rom is "optimised" for AnTuTu-testing
tell us more .......
Interested, know about this.
thanks
2013/03/15
kmeletis said
Hi,ÂÂ
Thanks for the firmware. I think I brick my tablet because it's stuck for two minutes in 3% Â upgrade and I pull out the USB cable thinking that something was wrong. since then it wont boot at all. any solution?
Thanks.
I had the same thing with this tablet.
it seems the micro-usb connection came a bit loose from the circuit-board inside.
therefore the tablet only makes a connection when the connector is slightly tilted upwards . (towards the screen). as long as you keep the cable under some tension, the tablet will stay connected.
Then i tried many of times to update the firmware with the known procedure (hold 'home' button while slowly press the 'power button' 10 times) but nothing happened. next morning i tried it once more, and after 2 attempts the tablet was just fine again.
2013/07/17
i found a "new version"(Date 10-09-2013) here.
http://pan.baidu.com/share/home?uk=389436537#category/type=0
Is this realy new ???
Currently Online: nicl
101 Guest(s)
Devices in use: Desktop (83), Phone (19)
pablovs
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
