[ ROM ] Onda V813 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.0 (2013-05-23)
greggoootz
2013/06/06 - 04:41
Admin, Awesome update!
It's like I got a brand new tablet...My v813 is now buttery smooth, with very little to no lag/freezing.  Even noticed the battery life is considerably longer.  2 hours of constant use, with 50% screen brightness, only drains 25% of the battery.
Be sure get this update installed, right away...
Keep up the good work...Thanks you!
gargonat
2013/06/09 - 23:33
Hello
First thanks for this rom.
My v813 tablet has been good, has improved in all aspects.
I'm still in testing, but for now a much improved over the 4.1.1.
Greetings from Spain.
Lo que sabemos es una gota de agua, lo que ignoramos es el oceano.
ymilev
2013/06/12 - 23:25
Making screenshot, as stated at http://www.onda-tablet.com :
Press simutaneously Volume-down (software key-the left one) and Power-on hardware key.
Tried it - works fine, but need to hold the keys for 1-2 seconds. You can do it by the left hand.
geek
2013/06/20 - 10:02
HELP PLEASE!! Google search and Google voice search no longer works after update.
Update:  when I used the tablet today it automatically did a Google Search update, and now all search functions work!!
teercee
2013/06/21 - 15:40
Does anyone know how to add the standard android /system/app/Contacts.apk that seems to be missing from both the onda Chinese firmware 4.2.2 & the rooted download here on arctablet.
Thanks Received: 3171
2013/06/26 - 11:37
tjfosjhp
teercee
2013/06/26 - 17:06
I have tried to use
ext2fsd http://www.ext2fsd.com/ and
osfmount http://www.osforensics.com/tools/mount-disk-images.html
to inspect the firmware images prior to install  or to try & and extract some of the zip apk filee but when i mount the img I get an error message invalid parameter  when I try to dbl click the mounted image in osfmount.
Has anybody been success full on a windows system mount & the firmware images ?
teercee
2013/06/26 - 17:30
83 Guest(s)
Devices in use: Desktop (66), Phone (17)
heftpflaster
rk.13
