Firmware build information:
Linux Kernel: Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Fri Jun 28 17:45:08 CST 2013
Android system: onda/fiber_onda809q9/fiber-onda809q9:4.2.2/JDQ39/20130701:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.41 (free version)
Download: kasty-onda_v812_v1-422-v32_20130701-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
This custom firmware has not yet been tested on the Onda V812 tablet (hardware V1 model)
ru.Egor, superkafer, datoxxl, Qsonic, to2todo2do, tabletfan If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
I'll have a look if I can find any changes Onda made between the two firmwares. In the meantime, I'm removing the download.
Grantlyjamespro If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/06/13
Can you reupload, i can't download always see...
Security error(6)
error logged, system administrator has been notified
Please reload this download page
Old files may have been removed, please check our web site or forum for latest updates.
2013/03/03
Security error(6)
yess true please reupload thanks
I have fixed the firmware and the download link, the file is available again, see post #1.
datoxxl, jelek92, imprez, fred64 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/02/17
V812 quad-core version _v3.2
1, optimize boot speed, new speed boot function
2, optimizing touch fluency, problem solving run Caton
3, updated GPU driver, enhancing stability
4, 4 K player with a new UI, to improve the user experience of many details of the operation
5, 4 K player, newly added video playback, support for screen rotation function
6, the backlight / Korea colors add intelligent control system
7, support Wifi download will not sleep while disconnected
(WIFI need to enter advanced settings option to "remain in the sleep state
WI-FI connection" option to manually set to "Always", will increase the system standby power)
The following users say thank you to lemon18 for this useful post:
primod808
2013/06/18
superkafer said
guma77 said
hi
admin how to disable startup, image Chinese girls ?dear admin,
same with me, how to disable it? thx
Try doing this use root explorer do systems, media look for the girl with the picture and delete it from the media folder. Haven't tried it but worth a try.
2013/03/04
I was able to eliminate the second Asian girl pic by deleting the bmp file in the system/media folder. Yet there is still one that shows up before the boot animation. I changed the boot animation but can't find the second Asian girl image file location. Is it cause its part of the actual rom image?
Currently Online: Micco, klaus1255
77 Guest(s)
Devices in use: Desktop (65), Phone (13), Tablet (1)
klaus1255
neverever007
favorit
Альфвоф
kevbez
xxxdddd
