Here is a new Android 4.2.2 Jelly Bean update for the Onda V812 tablet (hardware V1) based on latest Onda firmware release version 3.2. This update brings many enhancements such as a faster boot (5 seconds !) smoother system and a reduced power consumption in stand-by mode.
Firmware build information:
Linux Kernel: Â Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Tue Jun 18 12:27:17 CST 2013
Android system:Â onda/fiber_onda809q9/fiber-onda809q9:4.2.2/JDQ39/20130621:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.34 (free version)
Download:Â kasty-onda_v812_v1-422-v32_20130621-rooted.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Onda V812 (hardware V1) to test it.
jack10112319, jgon, kuleak, amienn If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/04/26
Great speed in the new firmware.
Regarding the poster about internal SD not getting mounted.
I think I may have experienced this. But I didnt realise the SD wasn't getting mounted. It happened twice and when some apps where saying not installed I did a factory restore as I thought corruption had occurred. Doh!
2013/04/20
jalaPavli said
Great boot up!Â
But my camera doesnt works, I have v5 tablet. Any idea?
Thanks, Greetings!
Apavli
Because this is the rom for V1 Hardware. You must use this http://www.arctablet.com/blog/forum/onda-v812/onda-v812-v5-hardware-android-4-2-2-jelly-bean-root-custom-firmware-v3-2-2013-06-21/
2013/06/10
Hi, this is my first post and my English is poor.
I test this rom and in the first moment is work very well, the boot is fast and with multiple app work better than V3.0.
In the battery I can't see diference.
Is faster and the I test the wifi, in the version v3.0 discconect in standby mode.
I like the porcentege in the battery
2013/06/18
Great rom it's really smooth and responsive thank you. Â I've been playing around and found that google now when you try to ask a question no voice is heard. Â I get a response which is correct bu no voice is heard. Â I checked all my settings for google voice and everything is checked out correctly. Â Should i delete google voice search and try to reinstall from the playstore?
Thanks again.
Currently Online: portvein
83 Guest(s)
Devices in use: Desktop (70), Phone (14)
montolla
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
