Well, first check your sound settings, but I supposed you already did so
Then try to reflash the same firmware, if the problem is still there, reflash an older firmware that you know was working and double check.
2013/05/29
Hi Everyone,
I have just finished adding this firmware and apart from ALL the apps going I'm very pleased because up until now I was unable to transfer from my PC to the Tablet.
This was because of another firmware "removing" the drivers. And the PC not "seeing" the Tab. Now I can report that after downloading and installing the apps I had on before, everything works as it should.
Including both cameras. So, thank you so much and keep up the good work.
Sandy
2013/02/17
litiume said
I just flash provided firmware on my v812 v1 tablet.I have no problem with the camera - it simply works. But something wrong with the sound - my tablet is silent always. Yes, just silent, no sound at all. I don't know why. Any suggestion?
May be 3.5mm Earphone port freezes.
2013/03/03
Well, first check your sound settings, but I supposed you already did so![]()
Thank you all for your responses
I'm sorry but this is my mistake. It was the hardware's issue, not firmware's.
2013/04/17
Hi All
I tried to use the custom firmware from this site. no joy. the top dropdown menus where swaped around ie i tap the left side and the right side droped down. the nemus where also unuserbale. i could not lanch the goole play app. when i taped the return arrow the sliding sound widget appered. plus a couple of other things. So i used the Onda site update. Great no problems, its a hughe improvemnet over JB 4..
still would like to use the custuom update though, your previous was good.
thanks
tim
Currently Online: avv2011
83 Guest(s)
Devices in use: Desktop (73), Phone (10), Tablet (1)
avv2011
leadpan101
jumbo65
kalkpits
m12k
StatusQ
