[ ROM ] Onda V812 root custom firmware v2.0 (2013-03-30)
julo
31
2013/04/13 - 20:04
arrasmith said
In the v972 forum they recommend downgrading youtube to get back video for that application. This also works on my v813.
http://www.androiddrawer.com/7630/download-youtube-4-2-16-app-apk/#.UWmdPhyUjiM
arrasmith
Kansas, USA
Forum Posts: 65
Thanks Received: 7
32
2013/04/15 - 00:00
Grantlyjamespro said
Howdy admin, joined forum to seek better firmware for my V812 because I could not find the download at the Onda site other than a chinese version at ondabbs. After downloading both Phoenixsuit and the kasty firmware upgrade I tried to do upgrade but the Phoenixsuit program showed a dialogue box after loading firmware that said "Jump to upgrade mode fails", but allowed me to continue. After shutdown of tablet and home button re-attachment it displayed "PnpFelln Error". Any advice what I may be doing wrong????
I can't share much beyond what I had to do for my v813.
1) Shut down tablet.
2) Launch Phoenix and point it to the new firmware.
3) Hold home button down and then plug-in the usb cable. I actually never had to hit the power button at all.
4) Windows XP would notice the new device and Phoenix would see it ... and then it would fail.
5) Wait until the PnpFelin Error and then push and hold the tablet's power button for 10 seconds to shut it off. Close out Phoenix. Unplug the tablet. AND .... Go back to number 2 and try again.
After lots of times through the cycle ... if would finally go. Have no idea why. Most likely because Windows is evil.
The following users say thank you to arrasmith for this useful post:
Grantlyjamespro
alchemygear
Forum Posts: 14
33
2013/04/15 - 15:18
Im on linux mint 14 can anyone provide a app or directions to flash with, as PhoenixSuite is for widows only.  I tried to flash it in the recovery menu but it always fails.  I had a coby kryos that I had not problem flashing in the recovery mode.  I also installed the clockwork mod easly but i bought this new onda v812 which is worlds better if only i could get the custom firmware to work.
alchemygear
Forum Posts: 14
34
2013/04/15 - 16:11
I have tried to get my onda v812 into fastboot mode but it reboots into adm mode so the flashboot install does not work.  I cant seem to flash with linux please help me.  I can use my wifes laptop but i really don't want too, i want to know how to do this in linux, please dont make me resort to windblows.  Linux people will understand why i feel this way.
arrasmith
Kansas, USA
Forum Posts: 65
Thanks Received: 7
35
2013/04/15 - 19:57
alchemygear said: "I have tried to get my onda v812 into fastboot mode but it reboots into adm mode so the flashboot install does not work.  I cant seem to flash with linux please help me.  I can use my wifes laptop but i really don't want too, i want to know how to do this in linux, please dont make me resort to windblows.  Linux people will understand why i feel this way."
I know how you feel. But, I haven't seen a firmware release the used the Update program on the tablet. The ones released at onda-tablet.com are all an archive with the .img and Phoenix Suite. Their updates keep talking about OTA updates. Be nice if they released those.
Has anyone seen a firmware for the Update program?
mywkk5005
36
2013/04/17 - 10:23
Dear Admin,
My v812 have a problem with "unfortunately, google play store has stopped" error. This message will be pop-up in every few minutes. This problem occurred after I upgraded to the 1.35 firmware. I've tried the below method:
1. clear data & cache in play store.
2. log out & reenter the google acc.
3. upgrade to the latest firmware v 2.0.
4. install the latest google play store.
The above methods cant solve the problem. Did I need to do factory reset?
Please advice..thanks.
Thanks Received: 268
37
2013/04/17 - 10:36
Try a factory reset, and if that does not work, try and re-flash the tablet.
38
2013/04/17 - 10:37
Reflashing could be a good opportunity to install latest 2.0 firmware which gives better performance and stability.
alchemygear
Forum Posts: 14
39
2013/04/17 - 17:31
My onda v812 wont go into fastboot mode.  In linux mint i have not found another way of flashing may tablet but using adb and fastboot.  With My coby kryos all I have to do is hold home then plug in the cord connected to the computer and at the same time tap the power button fast over and over then it goes to fastboot mode.  How do you do it with the onda V812 tablet.
isarac70
40
2013/04/20 - 13:05
My tablet versiyon; v812QAD3V5….
Does it work on this rom my tablet?
41
2013/04/20 - 14:46
I don't think it, looks like you have the hardware V5 for which Onda offers a specific firmware:
http://www.onda.cn/Tablet/ProductInfo.aspx?ProductId=240&d=down
We'll eventually build a custom firmware for the V5 if there is enough demand.
I'm curious what V5 appears, is that on a stick from the tablet ? or in the system settings in Android ?
ru.Egor, isarac70
ru.Egor
42
2013/04/24 - 06:24
Hello. Please build this custom firmware :)
The following users say thank you to ru.Egor for this useful post:
isarac70
shinchan
43
2013/04/26 - 18:47
Dear Admin, My v812 have a problem with "unfortunately, google play store has stopped" error. This message will be pop-up in every few minutes. This problem occurred after I upgraded to the 1.35 firmware. I've tried the below method: 1. clear data & cache in play store. 2. log out & reenter the google acc. 3. upgrade to the latest firmware v 2.0. 4. install the latest google play store.   The above methods cant solve the problem. Did I need to do factory reset? Please advice..thanks.
i just change build.prop into samsung galtab. then the play store worked normaly again
nick789uk
Forum Posts: 45
44
2013/04/26 - 21:47
Hi re flashed the rom with the fixed firmware due to some of my movies having diaganal green lines on, but still have the same problem does not effect all the movies only some, any ideas about this.
Nick
Bilirar
45
2013/04/28 - 12:16
Dear admin
AFter update everything works just fine except the camera, the device keeps saying that it cannot connect to the camera. Other camera apps and video call dont work, either. My device is V5 so i just wonder if this problem only applied to version5 devices. Hope you can fix this or make a custom rom using the 2.0 v5 version firmware because im really excited seeing how much better the device got after update. Thanks so much for your work. Hope ill be able to make video call soon. :) )
The following users say thank you to Bilirar for this useful post:
isarac70
151 Guest(s)
Devices in use: Desktop (146), Phone (5)
