[ ROM ] Onda V812 root custom firmware v2.0 (2013-03-30)
sonusony
2013/04/04 - 14:36
thx for 2.0 update... youTube does not show video..only sound
do we need to reset everything after uodate?
2013/04/04 - 14:40
Nope, this seems to be a problem with 2.0 update, it has also been reported by V972 users.
We're looking if there's anything fix we can provide, but it will more likely be fixed by a coming update from Onda, we'll post when we know about it.
arrasmith
Kansas, USA
Forum Posts: 65
Thanks Received: 7
2013/04/04 - 15:14
The no video for youtube is also on the V813 2.0 firmware.
litiume
2013/04/05 - 05:15
arrasmith said
Can you give a a more detailed description so we can know what to look for?
Basically what applications are you launching, what was the previous behavior, and what is the behavior under the 2.0 firmware. That way we can try and replicate the bugs on our tablets. It helps with finding the problems.
I do not use any special application on my v812, I think (just a neutral games like Angry Birds, Perry?, and some apps like Amazon Kindle, K-9 Mail, gReader, Viber, ...).
Lagging started immediately after flashing v2.0 firmware, and became more serious after I restore backed-up user apps using Titanium Backup. I was trying to clean Dalvik cache and fixing permission then with CWM-R, but nothing improved.
Every action, including access to the home menu and system settings was very slow. Especially when a download task is run (automatically app update by Google Play), each touch on screen should take 3-5 seconds to get response.
(Sorry for my terrible English).
jahras
2013/04/06 - 00:41
arrasmith said
litiume said
On my v812 v1, the new firmware lag and much much slower than the Kasty v1.35. Especially when running multiple applications at the same time (multitasking), my v812 make me feel like holding a single-core device. So, I have to go back to v1.35 and wait for a next better firmware version.
For example if you are seeing scrolling problems in the browser, it may be graphics driver related or it may be just a bug in the browser. One would require fixing the kernel and drivers. The other would just be replacing the browser or using a different browser.
How do you find your onda version?
Cheers
kcthomlau
2013/04/06 - 07:25
Cheers
look at the back of the device. it shows on the 9th and 10th digit of the sn
julo
2013/04/06 - 10:06
nick789uk said
Hi thanks for the rom used it on both my 812 and the version for the v972, sound appears to have improved the only problem I have on the V812 is now catch up tv has a black screen and only plays audio, same on the V972, also on the V812 kept getting goole play had stopped working until I did a factory reset appears to be ok now no error message but still only audio on catchup tv, may be something to do with flash as I believe catchup tv still uses this. nexflix, bbc iplayer and itv player all work,anyone els had these issues.
Nick
I have the same problem, youtube only plays audio - V812.
kuusod
2013/04/06 - 12:47
Hello sir would you give me a model v5 for v812 root rom plz.or give me a way to root my device.My device is onda v812 fw v2.0 model v5.It's can work with your rom almost perfect only problem is cannot use the camera.
oerp
2013/04/08 - 09:22
Hoi,
I have a slightly different issue:
I'm unable to install several apps (old original ROM or V2.10-41) - the apps are Google+, Öffi, NS Reisplanner,...
First I got the message that the App was incompatible with the hardware, after changing the permissions and copying
com.google.android.maps.xml
com.google.android.maps.jar
in the required folders (see i.e. http://www.slatedroid.com/topic/25334-fixing-the-install-failed-missing-shared-library-error/) I was able to find the apps, but the installation failed with the message "missing shared library".
How can I find out which library is missing? Or is there another way to solve this?
arrasmith
Kansas, USA
Forum Posts: 65
Thanks Received: 7
2013/04/08 - 17:18
Onda-Tablet finally released the v2.0 firmwares. And there are two different ones for the v812. One for the v1-v4 hardware. And one for the v5 hardware. The v972 also has differing firmware for the hardware variations.
See ... http://www.onda-tablet.com/news/
arrasmith
Kansas, USA
Forum Posts: 65
Thanks Received: 7
2013/04/09 - 20:43
In the v972 forum they recommend downgrading youtube to get back video for that application. This also works on my v813.
befa34
2013/04/10 - 09:57
Hello,  verry good job;
In Adrenaline 2:
http://www.htcmania.com/showthread.php?t=586353
compatible  V811  ! ? # 48
but with my V812  I have freeze after  4 mns
can you  inspire :
Adding a generic Bluetooth (USB ath3k Atheros chip)
Added support for USB Gamepad controls for Xbox360, PS3 and generic..
Added support USB2Serial
isarac70
2013/04/12 - 17:28
Hi.
My tablet versiyon; v812QAD3V5....
Does it work on this rom my tablet?
Grantlyjamespro
2013/04/13 - 15:23
Howdy admin, joined forum to seek better firmware for my V812 because I could not find the download at the Onda site other than a chinese version at ondabbs. After downloading both Phoenixsuit and the kasty firmware upgrade I tried to do upgrade but the Phoenixsuit program showed a dialogue box after loading firmware that said "Jump to upgrade mode fails", but allowed me to continue. After shutdown of tablet and home button re-attachment it displayed "PnpFelln Error". Any advice what I may be doing wrong????
Jammy007
Forum Posts: 18
2013/04/13 - 17:15
Yeah  im gonna wait for a new one, this one dosnt give video on youtube, or TV catchup
78 Guest(s)
Devices in use: Desktop (71), Phone (7)
jacksonrid
usdown
ibob64
kawi
vetBro
