[ ROM ] Onda V812 root custom firmware v1.33 (2013-02-28)
Thanks Received: 3170
2013/02/28 - 10:52
Onda has just published a firmware update version 1.33 for their V812 tablet, here is a rooted custom firmware update.
Build information
Android system: onda/fiber_onda809q9/fiber-onda809q9:4.1.1/MASTER/20130227:user/opinions-on-teclast-p90hdst-keys
Linux Kernel: Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Wed Feb 27 16:52:29 CST 2013
 Onda_V812_fw_133_about.pngImage Enlarger
Google Translation of the firmware changelog from Onda gives the following in Ch'English:
to enhance the stability of the system disk repair prompt
solve the 4.5 version of the call of the micro-channel noise problem
application installation space recovery 2GB capacity
perfect the OTA upgrade function
amended the previous version of the firmware some models random problem can not burn Note: firmware package included Brush tutorial and Brush tools; Brush risk, Brush
Please read the tutorial;
- root with latest SuperSU 1.20 (free version)
- added ArcTools for easy ClockworkMod Recovery (CWM) installation, see details here
We need your support to continue building and improving our firmwares, please consider making a donation if you appreciate our work. paypal_donate_small.gif
Download: kasty-onda_v812-41-v133-rooted3.zip
Rooted firmware verification:
Onda_V812_fw_133_root.pngImage Enlarger
This firmware has 2 GB storage space for applications (/data partition)
Onda_V812_fw_133_apps_2G.pngImage Enlarger
Dhavoy, sonusony, befa34, akincube, aryanitinkumar, quypdk, xavibta
Dhavoy
2013/02/28 - 12:30
Hi, Thanks for the file..can i directly flash this to unrooted fw v1.2?
What do I need to do first? thanks for the advice..
I'm just new to Android community and this is my first Android tablet.
The following users say thank you to Dhavoy for this useful post:
Pavlos Papadopoulos
2013/02/28 - 12:35
Please read the topic for our previous custom firmware, it works the same:
http://www.arctablet.com/blog/forum/onda-v812/onda-v812-root-custom-firmware-v1-32-2013-02-05/
lidel
2013/02/28 - 13:13
which are the main differences to the firmware 1.32? this firmware version ( 1.33) is better or not? thank you!
2013/02/28 - 13:20
Post #1 gives the changelog from the manufacturer, translated from Chinese.
I haven't tested the firmware enough to report changes, but it seems stable so far.
Dhavoy
2013/02/28 - 14:44
Thanks a lot!..there seems an issue when I try to flash unrooted fw v1.32(i have only the unrooted fw v1.2 the pop up window won't show up when  I try to fllash it. What I did was to reset it to factory settings and directly flash the rooted fw v1.33 and it works.
yes, it seems stable so far...Laugh
befa34
2013/02/28 - 16:50
Dhavoy
2013/03/01 - 07:13
Hi All,
Did anyone noticed/encounter after installing rooted fw v1.33, It's very difficult to turn it on the V812 tablet(after shutting it down) I have to press several times until the CPU logo appears. I dont think my tablet's power button has an issue because when the unit is turned on the power button works perfectly. Is there anyone encountering like this?
luca40
2013/03/01 - 08:38
I installed v1.33 and v1.32 I have no more than the problem of wifi and space devoted to the app has returned to 2 GB,
everything works fine and no problem.
If someone has installed the v1.33 could postarmi the app "update.apk"?
restoring an old backup I have overwritten the application with that of v1.32.
thank you very much
befa34
2013/03/01 - 09:28
with Fw 1.33 :  i can take photo (in mode camera)  but whene i select video film for make a vidéo     i have FC   you to?
2013/03/01 - 16:25
I've rebuilt the custom firmware (see post #1) now including latest SuperSU 1.20 and added ArcTools for easy CWM Recovery installation, please check details here.
befa34, jelek92
lemon18
Forum Posts: 13
Thanks Received: 7
2013/03/02 - 17:23
Firmware version 1.33 can't be installed game Blood Brothers,
but version 1.2 can installed complete from .apk.
gokuh82
2013/03/05 - 18:21
After installing this ROM i get the message to update the superuser in the play store. I update it and i notice that the superuser icon changes and then when opening it, says i need to update the binaries. Says that it fails to update. Tried to use other su update apps and there all a no go. Also cant write to the internal sd or mount the internal sd with es file explorer.
The following users say thank you to gokuh82 for this useful post:
jelek92
guma77
Forum Posts: 16
2013/03/05 - 22:46
very good rom  ,  boss when  nev version ;)
ps.how to hide or remove the status bar icon gsm mobile network ?
yeah_boy77
2013/03/09 - 13:33
i have installed the 1.33 fw.  but now i can't use the video recording of the camera.  it just says..."the gallery has stopped"
Please help....
102 Guest(s)
Devices in use: Desktop (90), Phone (12)
fantom0308
Morris028
robertgdfdgdfss
wtf
jdani20001027
thinkappleeight
