| Latest product reviews |
(1 votes) 22:15
OnlineJMI Pulse 10
Here is one of the first rooted custom firmwares for the Onda V812 tablet, it is based on latest official V1.32 release from Onda.
- root with latest SuperSU 1.04 (free version)
Download: kasty-onda_v812-41-v132-rooted.zip
Flash with [[** please register to see this link **]]
I am releasing this firmware for testers, but haven't tested it yet, for some reason PhoenixSuite does not want to put my Onda 812 in flash mode. I am confident it should work smooth as I built it the same way as my [[** please register to see this link **]] that is confirmed to work properly by several users.
16:36
OnlineJMI Pulse 10
The custom firmware we've done is a complete firmware image that needs to be flashed thru PhoenixSuit, that's the only option and it can not be updated thru OTA.
16:43
OnlineJMI Pulse 10
As i mentioned, it won't work.
The update application can do OTA updates online (WiFI) or offline, but it works only with update.zip type format which is different than the custom firmware we're supplying.
16:58
OnlineJMI Pulse 10
I don't know, but maybe when there are a lot of changed files the package is too big for OTA and it's better for them to put a full firmware build.
I don't think PhoenixSuit will work well with VirtualPC on a Mac, so it's probably best to find someone with a PC to help you.
17:20
OnlineJMI Pulse 10
I slightly reduced the system partition size but it doesn't have any impact on the storage space for apps.
I'll double check that once I can flash my firmware on the V812. For the moment, I'm stuck with "Begin to Upgrade Firmware to Device" and progress bar at 0% when putting my device in flash mode.
I'm open to any tips getting my V812 to flash my firmware ![]()
17:52
OfflineI had the same problem. What I did was flash Official Firmware v1.0, then v1.2 , then v1.32 and finally your Custom Rom using PhoenixSuit. Its a bit long winded but it worked. I Hope this helps.
The following users say thank you to darren553 for this useful post:
adminVery good job, after factory reset i have install this rom [[** please register to see this link **]] and ater installation i have factory reset.
it ok GMPT OK
Thank you
19:14
OnlineJMI Pulse 10
You're a star Darren ![]()
That was it, it's just not possible to flash v1.0 to 1.32.
I'm posting firmware v1.2 mirror in case anybody else need it: [[** please register to see this link **]]
I'll have a look at the apps partition size later this week-end.
08:09
OfflineNo Archos/Arnova device
Thanks Darren – great job!
I will check it later couse now I've got mine rooted (+ XML and prop.build set as GT-N8000) – what gives me chance to play BackStab and other games on great details. Promise to check it after weekend.
U mentioned to put here our ideas for next ROM. Here we go:
- App2SD script that is used inside CM (it makes that our SD card (extsd) works as the internal memory and sdcard – when u put 64 Gb sdxd u have plenty space for ur apps and apps data. Now u can install 2-3 Gameloft Games and there is no space for other). Here is what im writing about : [[** please register to see this link **]]
- Battery tweak – ffs its only 2h now!
- task manager (with widged) to clean RAM
- ES File Explorer
Thats all now. Thanks.
Greetings
22:38
OnlineJMI Pulse 10
I'm currently fixing the read only /system, will post an update soon.
Most Users Ever Online: 646
Currently Online: admin, minerva1961, globula_neagra, arrasmith, daisab, lolloarnova, giulia.spider, wallykoko, donylandes, Mist, HMB, algem, wildthing66, Jstavrou, lejem, frizbear91, lurker415, touno71, meshoo, kmiu, dstyle, Donkman, buzz360, pingu123456, Enr1988, paulusingo, Raska501, ryanchan, ru.Egor, PassieWaterm, rikkinadir, eldivino69, maurie13, hdonk, choupierre, IsolatedAbyss, lebasque93, elidoe89, df186, msev, stephkem, badbread, havefun4u, solexist1997, micronexus, nguyen0024, bigbejcek, Mada1, le lay, Ding90, eloco, bigcheek, frankdami, hitec7, kkox_, bolp, thijs1301, Allan72, Valdo, scorpio16v, hartm11
246 Guest(s)
admin: 3702
globula_neagra: 1885
Guest Posters: 36
Members: 75006
Forums: 123
Topics: 2818
Newest Members: vanomad, guru-mcdoc, hartm11, jesusgsx-r, lily, tam
Moderators: HaroldG (117), globula_neagra (1885), exelletor (344)
Administrators: admin (3702)
Log In
Register
Arnova and Archos support Forum
