[ ROM ] Onda V811 quad-core (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.0 (2013-05-23)
2013/05/24 - 19:24
Here is a custom firmware based on official Android 4.2.2 Jelly Bean update for the Onda V811 (hardware V1) tablet.
Firmware build information
Linux Kernel:  Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #28 SMP PREEMPT Tue May 21 11:51:35 CST 2013
Android system: onda/fiber_onda809q9d/fiber-onda809q9d:4.2.2/JDQ39/20130523:eng/opinions-on-teclast-p90hdst-keys
Common revision history for firmware V3.0 on Onda tablets (Google translate from Chinese) :
  1. Android 4.2.2 upgrade to version
  2. optimize the user experience, more responsive and smooth trolley
  3. brand new unlocked clock interface, display more beautiful
  4. new left and right pair of pull-down menu function, more convenient operation
  5. New increasing Day Dream screen saver function, Tablet PC can do a digital photo frame
  6. optimized 4K player that supports HDMI output with different screen display / different display function
  7. optimize system startup speed
  8. optimize the photographic effect, improving the camera snapshot function
  • root with latest SuperSU 1.30 (free version)
  • system default setup English
Download: kasty-onda_v811_v1-422-v30_20130523-rooted4.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Onda V811 to test it.
Thanks df186 for his support.
vlucia, smg, gurkan_gultekin
vlucia
2013/05/25 - 02:18
Thanks. Works so good!!
The following users say thank you to vlucia for this useful post:
trnguyen81, Jenni9046
obeguin
Forum Posts: 22
2013/05/25 - 04:02
Thanks... Just waiting for the same custom rom for v813, new firmware :-)
2013/05/25 - 12:01
Onda V813 custom firmware should be posted in the forum in a few hours.
arisdario
2013/05/30 - 12:57
I cannot update, I fallowed the steps, but phoenixsuit say: "No device to be upgraded" Any solution?
Panarra
2013/06/06 - 02:32
This is for the quad core version, not for the dual core v811 right?
smg
2013/06/06 - 15:27
@panarra:
yes its for quad
title is misleading, but you can see by this:
"Flash with PhoenixSuite (tutorial)"
Phoenix is used for new quad-tabs with Allwinner-Chips
2013/06/06 - 15:30
Hmmm, yea it looks like Onda has the great idea to keep the same name for dual and quad-core tablets Confused
I've add the quad-core mention in the topic title, I hope it's more clear for everybody now.
smg
Panarra
2013/06/07 - 02:19
Thank you both :D
gurkan_gultekin
2013/06/24 - 19:19
@admin thanks a million for this post, this has made my v811 core4 from crap to a useable/ more stable device.
however slow wifi download remains ex. slow play store app. downloads, facebook photo loadup times etc.
could you offer a solution to this problem.
fw v v3.0_v1
android v 4.2.2
kernel v 3.3.0
df186
Forum Posts: 16
2013/07/03 - 23:20
Hey admin.. is there any status on getting firmware 3.2 done? for the V811?
Nachtigall77
2013/07/07 - 11:45
V3.2 please!Cry
2013/07/10 - 10:57
57 Guest(s)
Devices in use: Desktop (53), Phone (4)
