Linux Kernel: Â Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) )Â #1 SMP PREEMPT Fri Jun 28 17:45:08 CST 2013
Android system:Â onda/fiber_onda809q9d/fiber-onda809q9d:4.2.2/JDQ39/20130701:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU 1.41 (free version)
Download:Â kasty-onda_v811_v1-422-v32_20130701-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
This custom firmware has not yet been tested on the Onda V811 tablet (hardware V1 model)
vnnhd, Nachtigall77, sdt, lequangthong, quangk If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/05/10
this works really good.. only issue i am finding is that internet is super slow.. which is not on the V818 (I have this one too) and im finding that i loose connection often as well.. otherwise.. works pretty fast.. but if we can get the internet thing working.. that would be great!
2013/07/29
I had the same problem, but fixed it by powering off, holding the home and power buttons simultaneously until the tablet boots into boot menu, and then selecting the clear cache option (touch screen for option). Tablet will automatically reboot. After that, have not had anymore problems with WiFi.
75 Guest(s)
Devices in use: Desktop (66), Phone (9)
chema1971
speedyftp
georgicaa97
kkn
LatifMohammadi
arthurmax01
