2015/05/08
Heloo all,
I have a serious problem with my allview alldro speed 2 quad tablet.After a restart my tablet always opened in recovery mode but in that menu i couldn't move down or up because the touchscreen seems that it doesn't answer to touch.I try different software and flash them with PhoenixSuit but until now i didn't find the right one.I try a original firmware(Allview2_M809Q5_20130903) from a thread but after i flash it the tablet open in the menu but the touch doesn't respond to command.
I tryed all version of Onda v812 software:
-V812Core4_v1.35
-V812Core4-V1_v2.0
-V812Core4-V5_v2.0
-V812Core4-V5_v1.35,but in all those version the camera and the wifi motherboard isn t recognized by the Onda software so i can't use camera and WIFI.
Anyone can help me with a original software for this tablet or a modify image firmware that works on this tablet?
2015/06/16
Salut,
Pentru Allview Alldro 2 speed quad core exista doua rom-uri care "merg" unul pe care il gasesti pe arctablet.com (cauta onda812 kitkat root ) celalalt il gasesti pe forum-urile rusesti pentru o tableta echivalenta facuta in rusia.
http://www.arctablet.com/blog/forum/onda-v812/rom-onda-v812-v1v2v3v4-hardware-android-4-4-2-kitkat-root-custom-firmware-v4-4/
kitkat-ul: merge doar una din cele doua versiuni (prima ) din arhiva, dar nu recunoaste touchscreen-ul si probabil nici perifericele.
Dupa parerea mea, Allview Aldro 2 speed quad core NU este onda812 - din cate stiu eu onda are 16GB flash intern, nu 8GB si de aceea (hw diferit) nu se potrives modulele de kernel.
Pe site-ul rusesc ( cauta Allwinner A31 1GB DDR3 8GB HDD tablet pe google si vezi forumul 4pda.ru unde se face referire la tableta respectiva ) exista un rom care merge instalat, doar ca probabil e diferit layout-ul flash-ului intern, motiv pentru care la pornire se blocheaza, ramane accesibil prin adb - poate pe aceasta cale ar putea fi "fixat"
Daca gasesti rom-ul original de la Allview, sau un alt rom care sa fie functional pentru aceasta tableta, as avea nevoie si eu 😉
So, there are 2 roms that should but are not fully working because hw differences. See links above.
Original rom needed
Currently Online: Альфвоф
68 Guest(s)
Devices in use: Desktop (54), Phone (14), Tablet (1)
Альфвоф
kevbez
xxxdddd
xxxddd
Kaydc__
jessicapeterson
