[ ROM ] Onda V712 (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2.1 (2013-07-30)
2013/08/10 - 17:37
Here is latest Android 4.2.2 Jelly Bean update for the Onda V712 tablet (hardware V1) based on newest Onda firmware release version 3.2.1 dated 2013/07/30
(V712Core4_v3.2.1_v1.rar)
Firmware build information:
Linux Kernel:  Linux version 3.3.0 (lgm@SzExdroid5) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Thu Jul 25 16:28:08 CST 2013
Android system: onda/fiber_onda704q9/fiber-onda704q9:4.2.2/JDQ39/20130726:eng/opinions-on-teclast-p90hdst-keys
Firmware version 3.2.1 revision history:
1, increase MIRACAST wireless display feature
2, optimize system performance
3, optimize tablet standby time
4, optimize HDMI TV output function, support 1080P input and Full Zoom
5, amended Chi reader does not recognize the local disk compatibility issues
6, amended in google play find Youku, and other parts of the application tuxiuxiu question
7, the amendment 4K player, vertical screen gestures invalid under the volume problem
  • root with latest SuperSU 1.51 (free version)
  • system default setup English
Download: kasty-onda_v712_v1-422-v321_20130730-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
ET3D
ET3D
2013/08/15 - 05:12
Thanks for the update. Unfortunately I'm no longer able to get my V712 into flash mode. This is the second time I'm trying to flash one of your firmwares and it worked fine the last time.
palmerino17
2013/08/30 - 06:12
sorry, the never sleep comment from other post was meant to go here...
how come the never sleep option is no longer available?
and why doesn't the developer never sleep work either?
adamoda
2013/09/12 - 21:07
Is this firmware dedicated for V712 V1 dual or quad core tablet?
2013/09/12 - 21:52
V712Core4  Wink
Cheers
adamoda
2013/09/12 - 22:29
Anyone knows, which is the latest/actual Android version for dual core V712 V1?
ondav712
2014/03/23 - 03:48
same question
ars999
2014/09/17 - 12:24
Thanks. I will try .
48 Guest(s)
Devices in use: Desktop (40), Phone (8)
nikitamaan
VMILCINOV
