2013/04/15
kiroyue said
I'm using this rom and I can't use the HDMI output I don't know why it does not work, however the cable works fine with two xperia neo V.Is there any way to check the port? Or make it works xD
It is likely to be just a lack of connection as the cable connector is not long enough on many Onda tablets.
see this thread for more info
http://www.arctablet.com/blog/forum/onda-v812/hdmi-cable-issues-v813/
Good luck
Pingu
nobody said
Hi Admin,
First of thanks for all the great effort so far. I did the silliest mistake by using it for v701s. Arrgh..
It's now showing just the A31 logo when booting up. Still I have hope that it could be rescued.
Admin, is it possible to create a root firmware for the v701s so that I could attempt a reflash?
Thanks a lot for considering this request. It will really help... Feel so stupid really doing it on the first day and spoiling such a tablet
I did the same thing as well I am stuck on screen cannot get it to go farther. Did you find solution?
yayshiny said
nobody said
Hi Admin,
I can install this Onda V711s quad-core Version _v3.2.1_v3 Official Firmware fine but anytime I go to use this rom it will not restart. So I have unbricked it but wont accept your rom. Any idea why that is? Am I doing something wrong. I am happy that it work now but does that mean it will only accept factory rom and not yours? is there something I am missing?
I'll see what I can do
2014/05/02
Hello ! I have a problem and if you can help me, I'll be glad. I own a tablet called Allview Viva Q7 Life and I think it's actually Onda V711s.
My specs are: A31 1Ghz Quad Core CPU, 1GB RAM, PowerVR SGX544mp 8 core, 1024x600 NON IPS dispay and 8GB Nand
and here it is for model confirmation: http://www.allview.ro/produse/tablete-pc/lista-tablete-pc/q7-life/descriere/
Recently Allview released an upgrade to KitKat 4.4 but it actually decrease performance, screen tranzitions and battery life. I made the upgrade with PheonixSuit but now I want the original ROM and the "producer" Allview do not have it. I am wondering if I can flash this ROM to my tablet and if it will work. All I remember is that the original ROM was a nurmuhammad JB 4.2.2 build.
Another difference would be the android key chain, I don't know what is for.
adythekiller aici ai ce ai tu nevoie merge si pe q7 life. testat. http://vivaq7.blogspot.ro/
Here is what you need for allview viva Q7 life and Q7
2013/12/04
paleo said
Just to update, whilst PhoenixSuit installed and ran in virtualbox under windows 7, i could not get the device to attach. So i did as suggested and installed through a regular pc, and all went swimmingly.Now, to configure twrp....
many thanks!
..and can i just add, it's great to be able to r/w to the sd and have the usbhost functioning correctly without having to add to the permissions.xml!
Hi
Can you give me backup from twrp? I installed rom on tablet, and now the tablet hasn't entered in flash mode. And i want to reflash this firmware with twrp.
Sorry my english.
Thanks.
124 Guest(s)
Devices in use: Desktop (117), Phone (7)
