[ ROM ] Onda V711s (V1 hardware) Android 4.2.2 Jelly Bean root custom firmware V3.2.1 (2013-07-30)
2013/08/06 - 15:53
Here is latest Android 4.2.2 Jelly Bean update for the Onda V711s tablet (hardware V1) based on newest Onda firmware release version 3.2.1 dated 2013/07/30
(V711sCore4_v3.2.1_v1.rar)
Firmware build information:
Linux Kernel:  Linux version 3.3.0 (Nurmuhammad@SRV2013) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Sat Jul 27 06:23:37 UTC 2013
Android system: onda/fiber_ondam704q6/fiber-ondam704q6:4.2.2/JDQ39/20130727:eng/opinions-on-teclast-p90hdst-keys
Firmware version 3.2.1 revision history:
1, increase MIRACAST wireless display feature
2, optimize system performance
3, optimize tablet standby time
4, optimize HDMI TV output function, support 1080P input and Full Zoom
5, amended Chi reader does not recognize the local disk compatibility issues
6, amended in google play find Youku, and other parts of the application tuxiuxiu question
7, the amendment 4K player, vertical screen gestures invalid under the volume problem
  • root with latest SuperSU 1.51 (free version)
  • system default setup English
Download: kasty-onda_v711s_v1-422-v321_20130730-rooted0.zip
After flashing the tablet, a Setup Wizard should display on first boot to configure your network, regional settings, etc… If the wizard does not appear, just disconnect your USB cable from the tablet, make a short press on the power button to turn off the screen. After the screen is turned of, press the power button for a short time again to power the tablet, the Setup wizard should appear.
nighty
nobody
2013/08/27 - 11:42
Hi Admin,
First of thanks for all the great effort so far. I did the silliest mistake by using it for v701s. Arrgh.. :(
It's now showing just the A31 logo when booting up. Still I have hope that it could be rescued.
Admin, is it possible to create a root firmware for the v701s so that I could attempt a reflash?
Thanks a lot for considering this request. It will really help... Feel so stupid really doing it on the first day and spoiling such a tablet :(
2013/08/27 - 11:48
You should find a stock firmware for your device on Onda website: http://www.onda.cn/
I may later build a custom firmware for the v701s, new firmwares are done in priority for devices where we have supporting users or high demand from the public.
nobody
2013/08/27 - 12:18
I would be very very much grateful. Thanks for the advice btw. :)
palmerino17
2013/08/30 - 06:06
How come the never sleep option is no longer there? And the never sleep when charging under  development menu doesn't work either :(
paleo
Forum Posts: 11
2013/09/09 - 10:58
Sorry for the noob question, but do i need to root my V711s before flashing this ROM, or will the ROM root the tablet during the flash process?
2013/09/09 - 11:02
No need to root before, the tablet will be rooted after the firmware has been flashed.
paleo
Forum Posts: 11
2013/09/09 - 11:10
wow, thanks for the swift response. May i ask another question: is there a linux version of phoenixsuit (i'm a kubuntu user) or is there an alternative method for flashing from a linux based pc? I've googled around but am a little unclear on this. In the past i've flashed various roms to my htc devices, but always using CWM or similar from within the device, and i'm not sure how to proceed here with this tablet (if it ever arrives from china......)
cheers!
2013/09/09 - 11:15
There is no PhoenixSuit version for other systems than Windows.
I think a user on our forum got it to work on his Mac thru a PC emulator, that may work on your Linux system as well, you'll have to test. Still, it's probably best to get hold on a Windows PC to do the flashing.
paleo
Forum Posts: 11
2013/09/09 - 11:20
Thanks, i'll try to borrow one. I can (and do occasionally) run vista in virtualbox, and though fine for the odd task, i'm not sure i'd trust it for flashing!
Thanks for all the advice
paleo
Forum Posts: 11
2013/10/22 - 12:00
Just to update, whilst PhoenixSuit installed and ran in virtualbox under windows 7, i could not get the device to attach. So i did as suggested and installed through a regular pc, and all went swimmingly.
Now, to configure twrp....
many thanks!
..and can i just add, it's great to be able to r/w to the sd and have the usbhost functioning correctly without having to add to the permissions.xml!
paleo
Forum Posts: 11
2013/10/22 - 12:35
and a final update...
can confirm that twrp installed on my clean system, and is working. I installed the version for the V711s made by Christian Troy over at slatedroid, and have successfully backed up and restarted the tablet!
Drzack
2013/11/03 - 19:45
What about Batery Life after Root ?
gunnar1919
2013/11/04 - 22:27
Hello.
Thanks for the upgrade, it works great. I am looking for encryption on my Onda V711s, is that supported?
/Daniel
hawaii99
2013/11/18 - 20:58
hello
i  have a ployer momo20s  and i have test this rom.
every thing is working wifi sound camera HDMI but the screen is not working .
i have testing it by hdmi
But this rom is fast and 100% better than the momo 20s om.
can you help me building this rom whith working screen?
sorry for my bad english
greets patrick
78 Guest(s)
Devices in use: Desktop (60), Phone (18)
dandan7932@gmail.com
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
