2013/03/07
Hello everyone,
I just got my tablet ONDA V711S V3 MODEL today.
As always ordered from http://www.hongkongeek.com with 0 customs fees and delivery in 4 days via DHL for 5 euros.
The original firmware is : v3.2.1_v3
http://pan.baidu.com/s/1eMtmw CN Server
or
http://cake1974.free.fr/V711sCore4_v3.2.1_v3.rar FR Server
And here PhoenixSuit 1.05 English to flash the rom.
http://cake1974.free.fr/PhoenixSuitPacket_v1.0.5.zip
What is important is the V3 and yes it's brand new ... but there is a method for rooter beast.
Download here ROOT A31 :
http://cake1974.free.fr/Onda_Allwinner_A31_root_v1_0.zip
Then in the local memory use and the application of origin " UPDATE" and flash the file Onda_Allwinner_A31_root_v1_0.zip
Below is a tutorial to update your tablet with PhoenixSuit
Where to find the latest versions :
For onda is here: http://www.onda-tablet.com/news section news on onda -tablet
Please note , take the appropriate firmware to the version of your tablet
Prerequisites :
1 - use WinXP, Win7 system, connected to the USB port on the computer USB cable.
2 - Make sure the tablet is more than 50 % battery
3 - disable anti -virus software on your computer ( antivirus software can interfere with or block the processuce ) .
4 - Having downloaded the zip update (firmware )
Note:
1 - Remember to make a backup before updating , so be sure to remove the microSD card ;
2 - Read the instructions before the shift , there is always a risk of malfunction , this is here to help , thank you not to hold me or the forum for any problems occurred during installation ;
3 - The driver is not installed correctly, the device manager shows: Please uninstall the drive and reinstall ;
4 - If the Update fails, disconnect the USB cable and press the power button for about 20 seconds to force the tablet to stop and then start step tutorial 3.1;
Procedure:
1 - extract the downloaded firmware , the following figure shows :
You will find three files : a tutorial in Chinese word , an image file ( this is the shift in question) , and the installation file PhoenixSuit
2 - Install PhoenixSuit tool :
In the extracted folder , double -click the installation file PhoenixSuit , follow the steps below:
http://img15.hostingpics.net/pics/484539752.png
In this step , a pop-up window may open . In this case, click the following window, or press the button to continue to install the driver:
http://img15.hostingpics.net/pics/618679523.png
At the end of the installation, a shortcut icon is created on the desktop.
http://img15.hostingpics.net/pics/694017774.png
Firmware installation will be able to start !
3 - PhoenixSuit run the tool , start flashing Firmware :
3.1 Double- click PhoenixSuit which is now on the desktop ( or via the Start menu) icon, the following interface appears:
If a small window opens (updated software ), be sure to close
http://img15.hostingpics.net/pics/232304595.png
3.2 Go to the tab selection firmware by clicking on the anchor. After selection of the firmware, press the green button.
Help yourself steps below to select your downloaded firmware ( image file)
http://img15.hostingpics.net/pics/545570146.png
http://img15.hostingpics.net/pics/965022467.png
http://img15.hostingpics.net/pics/789416428.png
3.3 Tablet PC first. If you can not determine if the shutdown state , you can press the power button for 10-20 seconds to force shutdown .
3.4 Home button on the tablet ( with the printed side with a small house icon button) hold , connect the USB cable, then press and hold the power button 5-10 times bottom corner until you are asked to find new hardware and install the driver ( window at the bottom right of the computer screen ), release the Home button , as shown below and install correctly driver:
http://img15.hostingpics.net/pics/923130259.png
Tips :
a. automatically appear repeatedly in a new window hardware , the driver is automatically installed ;
( b) If the driver is not installed automatically , you can manually update the path to the installation directory . The default path is C: Program Files AllWinnertech PhoenixSuit Drivers AW_Driver ... ;
c . If you use the computer that you already used to install a SHIFT , this step is not necessary
3.5 Once recognized tablet, just follow the instructions below:
http://img15.hostingpics.net/pics/1649913010.png
With this, the upgrade is complete.
Close the tool update , disconnect the cable , USB tablet manual start . After the update is complete, the first starting time will be longer, please be patient for a while.
Sorry for my English that Thx Google Translate
The following users say thank you to cake1974 for this useful post:
mickaculous, irishpancakeIn case you missed it we have a tutorial for PhoenixSuite
2013/06/19
I cant get my onda v711s v3 to connect to pheonix suite debug is checked......i installed your root beast via local update but could not get internet after getting root access.....is there any other way i can get rid of chinese apps.....finallly got wifi back working after factory reset...thought i had bricked device....any help will be greatfully received.
factory reset the device and started from scratch....rooted my v711s (hardware version v3) through local update again this time worked swimmingly......delete those pesky Chinese apps.
Still can't get my device connected to Phoenix suite, but don't care as all is now well
Thanks uploader and sorry for any negativity on my part
2014/03/15
Thanks to cake1974 man, for the Root method.
Like you, I got the v711s V3........also from Hongkonggeek!!
no customs to pay, really good service, good tracking, etc.
this "rooter beast" method worked first time!!
This is Android 4.2.2
Firmware version is V3.2.5_V3
Newer F/W here:
http://www.onda.cn/Tablet/ProductInfo.aspx?ProductId=252&d=down
Or faster here:
V3.3.1_V3
https://disk.yandex.com/public/?hash=X2aaFfTRUN5S1y3lR902fK/qxlsz3Ff5f516vhOEDAU%3D
V4.4_v3 [KitKat Beta]
https://disk.yandex.com/public/?hash=teNu9%2B7sKbLRCtS%2BzAb/zMrcgUHnUak28I1w/MABciI%3D
Currently Online: VMILCINOV
53 Guest(s)
Devices in use: Desktop (47), Phone (7)
nikitamaan
VMILCINOV
