2013/12/24
Hi all
I have an Onda V972
Model: V972 Core4
Firmware: 3.3.1_V2
Kernel: 3.3.0
I tried to follow this tutorial to install CM 10.2
However, I made a mistake and rebooted before installing gapps.
Now, it boots, but touch is unresponsive. I cannot select Lang etc, to proceed with setup.
I tried to do the process all over, but I cannot copy files, since I cannot press the "Enable USB" prompt
I am trying to copy files with ADB, but I am getting "error:closed" all the time.
Tried on Win7 x32 & Win10 x64
Any ideas?
Seems nobody around here. I am not familiar with Allwinner architecture, but I think you need to install the compatibility fix for your device, as it does contain the right touch controller driver. In TWRP you should be able to use an USB mouse.
2013/12/24
Seems nobody around here. I am not familiar with Allwinner architecture, but I think you need to install the compatibility fix for your device, as it does contain the right touch controller driver. In TWRP you should be able to use an USB mouse.- Oma -Â Â
The thing is that I cannot do anything.
I am copying files to the SD Card, but when I am using recovery to install there is nothing
I cannot access the internal storage with ADB or Phoenix.
How can I do anything ?
So, TWRP is running?
At this stage there might be no internal storage (not formatted i.e.). Pls use an external sdcard.
2013/12/24
So, TWRP is running?At this stage there might be no internal storage (not formatted i.e.). Pls use an external sdcard.
- Oma - Â
I don't know how to run TWRP...
I am putting the device to recovery mode using it's buttons.
I can see the internal storage, however I cannot see the EXternal, so I cannot copy any image there to install.
86 Guest(s)
Devices in use: Desktop (74), Phone (12)
culo1
dfrt
PQNY
chema1971
speedyftp
georgicaa97
