Onda v819 Android 4.4 Avalabile
vlad0n
Forum Posts: 19
2013/12/20 - 07:53
http://www.onda-tablet.com/news/onda-v819-v44-kitkat-firmware-download/
Android 4.4Image Enlarger
Download: http://pan.baidu.com/s/1tLCWG
I have Onda 818, somebody who have Onda 819 please try the ROM to know what is run. :-)
senniha1994
Forum Posts: 11
2013/12/20 - 13:41
UNABLE TO DOWNLOAD IT ALL TIME THE SERVER DROPS IN REGULAR DOWNLOAD AND IN ACCELARED DOWNLOAD ALSO STOP AND HAS NO RESUME.I HAVE THE PREVIUS 4.4 IS MUCH BETTER IN MEMORY AND ALSO OVERCLOCKS CPU 1.2 IS ROOT BUT NOT SUPERUSER COS THE BINARY FAILURES TO UPDATE.
vlad0n
Forum Posts: 19
2013/12/20 - 14:53
Yes, the server don't work for the moment, I hope to resolve that problem . :-)
senniha1994
Forum Posts: 11
2013/12/20 - 18:24
you should try [custom rom] CyanogenMod 11 (4.4.2) for Allwinner A31 by ChristianTroy - update 2013-12-19 only for SDK 3.2 devices
2013/12/20 - 23:53
I have reuploaded the file on our servers (repacked in rar format) : v819mini_v4.4demo.rar
While there is no proper version number on the firmware file, it seems to be a newer update than previous KitKat version. Kernel signature is:
Linux version 3.3.0 (lgm@SzExdroid2) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Mon Dec 16 12:47:06 CST 2013
senna
2013/12/21 - 00:32
dear admin,i cant download the file,i have log in but i only see a message of hello and nothing is this adblock problem?
2013/12/21 - 00:40
try to login again here http://www.arctablet.com/blog/wp-login.php
then go back to the download page.
senniha1994
Forum Posts: 11
2013/12/21 - 00:55
Same thing,it logs in the profil status then go back to download section but again ask to register
F
vlad0n
Forum Posts: 19
2013/12/21 - 18:08
Because I didn't try it, i want to know what version is ?
Android 4.4 or 4.4.1 or 4.4.2 ?
senniha1994
Forum Posts: 11
2013/12/21 - 18:59
Dear admin,
     I have installed the new firmware.its flawless,run smooth,no lags,with great speed.its much better than the previews 4.4 demo.it needs root access,more internal memory (1 GB now) at least 2 even 3gb for applications.also I have see than the memory it reduced again to 706 mb like the 3.3.1 versions,in the previous beta 4.4 was more available I think about 800mb.in aututu x test gets 13984 and the CPU runs at 1200 default.I have screen shoots but I don't know how to upload.looking forward for a custom room rooted.
SmileLaughCheers
vlad0n
Forum Posts: 19
2013/12/21 - 19:16
http://postimage.org/
Try this, i really apreciate you if you post some screen.
Respect :-)
Hung
Forum Posts: 13
2013/12/22 - 05:47
how to root android 4.4 onda v819 mini
vlad0n
Forum Posts: 19
2013/12/22 - 11:01
senniha1994, I really appreciate you if you post some screen with the interface and menu. Thank you very much. :-)
Battery how is it ?
senniha1994
Forum Posts: 11
2013/12/22 - 13:37
the interface is the classic 4.4 with onda pre-install programms which are chinese.So i removed then all expept 2 which i cant remove.i changed also the lancher with nova.The battery of the table is small and it not last up to 5 hours with web use.onda claims 8-10 hours hd movie use.which is a big marketing lying.for the battery users must compare each other to make better conclusion.
157 Guest(s)
Devices in use: Desktop (152), Phone (5)
jacksonrid
usdown
ibob64
kawi
