VMax Mod is a smart microprocessor controlled electronic cigarette,that uses the lastest technology to allow you to set a range of voltages. Vmax is a great e-cigarette vv mod from Ecigsbuy. It is greatly built and with the 510 connection. It is very lightweight product so that feature makes it comfortable to say the least about it. It comes with a short protection and is a very safe device to use. In short a great product from Ecigsbuy with durability and performance. Works with variable voltage, you can adjust the Volt and and the Ohms depending on your needs. The Battery VMax operates from 3 to 6 Volts.Â
Specifications
Output Voltage: 3.0~6.0v, wattage from 3.W-15W
LED screenÂ
3-6v,0.1v stepÂ
allow 5amps currentÂ
improved button,never stuckÂ
Amperate Limiting 5 ampsÂ
Function of Vmax
1. Built-in three digit display allows you to visually adjust your voltage
2. Output Voltage:adjustable from 3.0v-6.0v in 0.1 volt increments
3. Discharge voltage: 6v-8.4v
4. Quiescent current:<100uA
5. Step-down regulator
6. Battery:stacked 2 pcs IMR Nipple 600mah 18350 battery
7. VMax can handle 5Amps or even bigger current
8. Protection against short circuit. Protection against installing the battery backwards.
The mod monitor the battery voltage and automatically shuts off when the battery is discharged.Â
Package contain
1 * Battery tube with control head
2 * 18650/2200mAh 3.6v Batteries
1 * Wall Single Battery Charger
1 * 510 eGo Style Clearomizer
With its built-in three digital display there are no analog dials or protentiometers to wear out.There's no way to accidentally reset the voltage and you  can make changes within seconds.Vmax allows you to digitally dial in your favorite voltages on its mini display.You can adjust the voltage from 3.0 to 6.0 using the built in user interface.
If you're tired of good vapor at the start of a new battery and weak vapor at the end, then the VMax variable voltage ecigarette is for you! The VMax is a microprocessor controlled variable voltage ecigarette that lets you adjust the voltage in seconds with just a few presses of a button. Â
Our variable voltage e cig has a regulated output which keeps your selected voltage the same with each puff regardless of your remaining battery power. As the battery drains, the great e cigarette will keep the voltage consistent giving you the perfect vapor throughout the day.
73 Guest(s)
Devices in use: Desktop (64), Phone (9)
Brainticket
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
