[ ROM ] Nextway F9X root custom firmware v2.0 (2013-04-03)
Toto13
2014/02/25 - 22:18
... problem solved, just very bad mechanical hardware quality. These chinese females require a bit more rough and deeper inserting Wink
PabloGallucci
2014/03/26 - 20:59
hi guys, how are you doing.
i have a nextway Fast 9x, and was dead.
i flash it with the rom posted here, now is alive but touch not working. do you have any other rom to try?
let me know please, thanks!!!
pablo.
rikoto
2014/03/27 - 11:20
Hello Pablo,
you have a f9x v2 Hardware,   because of this the tablet's touchscreen don't work.
Use a firmware made for f9x v2 hardware, you can find easily searching in google.
I'm using a CM 11.2 with path for f9x v2, for me is the best firmware that I have found.
Regards,
iligr
2014/04/01 - 09:51
i have tried this firmware (sun6i_android_fiber-sochip-sc5079_sdkV2.0_130407v1.img) on my Nextway f9x for more than a month now and i like it very much. I had a serious problem with the lags in the original firmware and i am very happy with the fact that the lags almost dissapeared.
I am only facing one problem and that is that i can't use the front camera with skype. I tried different versions of skype but the problem remains the same. I can see the other person's cam and i can also see my front cam in skype while videocalling, however the other person can only see a bright green instead of my cam. When i change to the 'back' camera everything works fine.
Please if you have any ideas or suggestions let me know
thanks
ilias
jazzman123
2014/04/06 - 12:00
Can this ROM be flashed on a nextway e9x rk3188?
Thank you in advance
Thanks Received: 3177
2014/04/06 - 12:16
This custom firmware is designed for the the Nextway F9X based on Allwinner A31, it won't work on tablets running on the Rockchip processors such as the Nextway E9X.
I may have a look for your device, can you point me to E9X latest stock firmware ?
jazzman123
2014/04/06 - 12:18
I think this is it: http://pan.baidu.com/share/link?shareid=154580&uk=153850079 but my chineese is a bit rusty :-)
cybernerd
73 Guest(s)
Devices in use: Desktop (70), Phone (3)
trroll171717
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
