| Latest product reviews |
(1 votes) 15:22
OfflineJMI Pulse 10
Here is a rooted custom firmware for the JMI Tab T970v2, it's based on latest firmware available from JMITech (2012/10/01).
- root and latest SuperSU (version 0.99 free)
- writable /system
- extended application space to 2 Gb (versus 1.0 Gb on stock firmware)
- Google Play Store fixes
File download: [[** please register to see this link **]]
This Firmware is only for T970v2, don't use on the older model (T970v1)
Flash with [[** please register to see this link **]] (in French)
ludoviclt, manumalLast edited by admin on 2013/01/05 - 15:23
21:30
Offlinehello i have a jmitabv2 with actually the orgos v1-0C rom installed
i have the cw-based recovery v5.5.0.4 installed
i would like to know how to transform your rom compatible with recovery rom
if i install your is my cw-based recovery v5.5.0.4 will be delete
sorry for my english
bonjour j’utilise actuellement la rom orgos v1-0c ainsi que le cw-based recovery v5.5.0.4
pouvez vous me dire si vous pouvez transformer votre zip pour qu'il soit compatible avec le recovery ou alors me dire comment le faire
si j'installe votre rom avec l'outil flash, cela va t'il supprimer mon mode cw-based recovery v5.5.0.4 ou non
merci
22:49
OfflineJMI Pulse 10
Flashing our firmware (post #1) will erase all your data and remove the existing recovery to replace it with the default one provided in the stock firmware.
Still, it is possible to flash our firmware, then flash just your favorite recovery image. You'll need RKAndroidtool, your CWM Recovery image file and the parameter file from our firmware.
Another option is that we rebuild our custom firmware with your CWM Recovery built in, but I won't be able to do that immediately.
13:52
Offlineok so i have to wait for your recorvery version then
thank a lot
for the moment i found this version cm10 v2.0 that is ok for my jmitab v2
14:14
OfflineJMI Pulse 10
I should be able to do it no problem, but I haven't had time to work on that lately, I should have a look soon.
ludovicltMost Users Ever Online: 646
Currently Online: jajonesss, valerunchiks, cucurucu, dia, gandus, themarkh, Lumen2003, ducados22, rayman, kenghua, pingu123456, iszeocs, 1alex1, fatt4h, Original, stef_2279, pas1970, kelemenlajos, neosystem, glotzi, traysub, Boris Wallsten, stilet69, Evdok, joophunk, kappa, Athlete, fecnipsis, matjazz, Techie20, noiramigo, muxah
205 Guest(s)
admin: 3940
globula_neagra: 2029
Guest Posters: 39
Members: 82980
Forums: 132
Topics: 2985
Newest Members: zsngcufbvu, muxah, muxah87, cdhgiq, noiramigo, lesur
Moderators: HaroldG (117), globula_neagra (2029), exelletor (344)
Administrators: admin (3940)
Log In
Register
Arnova and Archos support Forum
