2013/08/27
JochenKauz if what you tell about is only cpu related then those higher benchmark scores are coming only from gpu and ddr oc and not from the cpu? So 1800 would be working as 1600 but shown in cpu monitoring as 1800?
How would you start a kernel project for a specific tablet if there is no kernel source for it? Im just curious and i hope you guys are able to!
2012/11/19
Hi ManuPC,
I think I could best explain the problem with this:
https://github.com/crewrktablets/rk30_kernel/commit/c93447601546838855533adaa88dc5ac7a7507c7
Don't know if you ever compiled a kernel by yourself..
Look at the commit I made, and ignore the unimportant deletes.
The changes needed for Overclocking a RK3x is much more complicated than only changing a frequency table, this was only the case in RK2918. The above changes are for RK3066, but the difference to RK3188 is not great, the principle is the same.
If you are a lucky guy, the limits are only in the frequency table (board-xxx.c), then all is fine and in your case it seems you are a lucky guy.
You could check if this really works with NoFrills. In the app you can see if the stepping works (statistics). In the stats you can see how much processor time is spend in what speed step. If the limit is on, you never reach the 1800GHz, if it goes to 1800GHz no limit is applied from the clock-data.
Regarding kernel development..
It's a really hard way.
We search for kernel sources all over the world. Then we look what can be useful, even it is a 3.0.8. We merge changes from Android mainline 3.0 kernel. And we do reverse engineering by disassembling the kernel to find the right sources and parameters to use.Â
The stick sources are crippled and in much places not usable, cause sticks don't have so much things we need for tablets, like LCD, gsensor, touch, battery and so on. The complete framebuffer differs from tablets, cause they have always HDMI output, no LCD.
But... luckily RK3188 differs not to much from RK3066 and we made some good steps in Genio RK3066 to get it running with CM11. At this point we have a booting RK3066 kernel 3.0.36 with CM11. Our problem right now is only the touch, a weired chip in combination with the PWM. Lets see what we get.
Regards
JochenKauz
2012/11/19
You need a hex editor for this. But be aware patching the wrong parts, you can make the kernel unusable or even brick the tablet. So you really should know what you are doing!
2014/01/17
You can modify the following way? I know it will become brick, but I want to study it!
thanks so much!
        itdiy
2012/11/19
I think I could, but I'll only do things that are safe for me and others.
It is one thing to brick my own device, a complete other thing is, to do it for someone other.
A while ago I completely bricked a Odys Q from a member with a homebrew kernel of mine, after that I said to me, never do this again without testing it before on my own device. And if I say completely brick, I mean completely. After flashing that kernel, the only thing it was worse for, was to act as a nice 250 EUR expensive plate to put whiskey glasses on.
Some notions on the subjects below are probably required if you want to be able to understand what you do and safely patch the kernel like manupc did:
- hexadecimal notation and byte ordering
- C code compilation and how a source code ends up in the object/binary code
- file patching
- kernel image manipulation for Rockchip devices (checksum calculation)
Are you comfortable with these ?
Regarding the fact a tablet brick is nothing to worry about, I think it would be more responsible to assume yourself the consequence of your manipulations, I don't think it's fair nor it's not the role of a repair center...
Oma7144, JochenKauz If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/11/19
Regarding the fact a tablet brick is nothing to worry about, I think it would be more responsible to assume yourself the consequence of your manipulations, I don't think it's fair nor it's not the role of a repair center…
thanks for this clarification!
You are absolutely right with this, and that is the reason I only make this on my own devices. I know the risk, and it is my risk, not something I can delegate to the manufacturer in case of failure.
adminPer aspera ad astra, we rock the Tablets !
2013/06/01
Hi manupc,
as I'm happy with your overclocked kernel on the X2 and as I've switched to the mini3 retina on 2.1.0 Kasty ROM in the meantime I wanted to ask you if I could use your kernel for this tablet/ROM ?
Thanks in advance !
EDIT: Thanks to sbr.harry we've received a solution from fdzonerom. More infos under http://www.mobile01.com/topicdetail.php?f=605&t=3804029&last=49180667
368 Guest(s)
Devices in use: Desktop (93), Phone (275)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
