[ ROM ] FNF iFive X3 (refined model) Android 4.4.2 KitKat custom rooted firmware based on v2.1.6
2014/11/17 - 20:45
Here is an Android 4.4.2 KitKat rooted custom firmware for the FNF iFive X3 tablet (refined model). This firmware is based on the official iFive firmware 2.1.6, it should be used only the iFive X3 refined model, not on the older/regular X3 where it has some compatibility issues (mostly camera problems).
(F313_V2.1.6_201410100946.rar / F313_V2.1.6_201410100946.img)
400xNxpipo_m9_pro_android442_kitkat_20131226_kitkat_b.png.pagespeed.ic.OX66oTHP96.jpg
Build information:
Linux Kernel: Linux version 3.0.36+ (root@five-server2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #49 SMP PREEMPT Wed Jul 2 10:59:06 CST 2014
Android build: IFive/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140702.142843:eng/test-keys
ro.product.version=2.1.6
RK3188Loader(L)_V2.10.bin
  • root with latest SuperSU version 2.16 (free version)
  • increased space for applications (/data partition) to 4 GB
  • disabled OTA updates (may cause problems)
  • added Google Experience Launcher (GEL) in addition to iFive stock launcher
  • optional package to fix broken apps (Contacts/People and Calendar sync)
  • included temporary fix for multi-user support, thanks to didierm
  • optional ClockworkMod (CWM) Recovery easy install package
Download: kasty-fnf_ifive_x3-442-216-rooted4_mu.zip
Use Rockchip Batch Tool version 1.7 to flash the firmware, use Restore button.
We need your help, if you like our work, please support us to keep the site alive and contribute to our efforts.
Please report any problem with this firmware, I can’t verify this custom firmware works as I don’t have an iFive X3 to test it.
Oma7144, turist4, chewyfood
turist4
Forum Posts: 37
2014/11/17 - 21:30
downloading right now
angelO_o
Forum Posts: 15
2014/11/17 - 22:09
Nice!
I hope this version will be better than previous. Until now the only good version is the first with android 4.2.
Is there any new tool to install the firmware? I have windows 8.1 and I can't with Rockchip Batch tool. I must find pc with other version of windows. :/
@Trust write your impressions of this rom. :)
chewyfood
Forum Posts: 25
2014/11/17 - 23:06
going to try this as soon as it downloads. will report back.
iFive X3 | Minix Neo X5 | Samsung Galaxy S2 i777 | Samsung Galaxy S4 i337
turist4
Forum Posts: 37
2014/11/17 - 23:16
All works fine thanks to admin!
chewyfood
Forum Posts: 25
2014/11/18 - 02:29
Yup, works fine on my end too. Thanks admin!
angelO_o
Forum Posts: 15
2014/11/18 - 11:05
Are you sure that everything works fine? I just installed and I check that there is big problem with camera. Everything is opossite and there is no choice to change for use the back camera.
turist4
Forum Posts: 37
2014/11/18 - 19:40
you are right the camera is upside no option to change
benkenobi1204
2014/11/18 - 21:23
I confirm that camera isn't working...
angelO_o
Forum Posts: 15
2014/11/18 - 22:28
How can we contact with company to inform bugs?
I sent email to the follow site
http://www.ifive.com.cn/contact/
I hope to do something soon.
chewyfood
Forum Posts: 25
2014/11/18 - 22:44
that is pretty funny. I guess it just proves that no one uses the camera on the tablet lol...
Anyway, the e-mails of the people you should contact are:
linct AT ifive.com.cn
dailei AT ifive.com.cn
(I was given those back in February by someone on their staff as the people to contact for bugs)
I would also CC:
wanghui AT ifive.com.cn (he is the guy who actually responded from their staff that gave me the other two email addresses)
angelO_o
Forum Posts: 15
2014/11/18 - 22:58
I use the camera mainly for video call via skype. I think that this is serious problem!
Thanks for emails. :)
angelO_o
Forum Posts: 15
2014/11/19 - 10:07
Finally this version is not for the ifive x3. It is for ifive x3 Refined version. It's new model and the firmware in not compatible with old version.
@admin please change the title.
I told them to fix the problems for V2.1.3. I hope to do something..
2014/11/19 - 10:12
Thanks for the detail angelO_o.
The topic title and custom firmware description have been updated.
Please let us know if iFive updates their firmware for the older X3, we'll make a new custom firmware.
chewyfood
Forum Posts: 25
2014/11/19 - 11:49
I saw the word "refined" in translating the iFive fans forum, which is what is linked from the support/download site at iFive's website. I thought it was an error in the translation. Seeing as how you are using the word in plain English, there must be some meaning to it lol :D.
What does "refined" mean with regards to android ROM's?
EDIT:
OK, I understand what "refined" means now after a little googling. Apparently, iFive made an update for the X3 called the "X3 refined". I was unaware of this. So now my question is what is the difference between the old and refined versions?
Next question after that is...besides the camera, is there any harm running this ROM on the X3 old? Everything seems to work great and is very speedy.
133 Guest(s)
Devices in use: Desktop (127), Phone (6)
jacksonrid
usdown
ibob64
kawi
vetBro
