Here is an Android 4.4.2 KitKat rooted custom firmware for the FNF iFive X3 tablet. This firmware is based on the official iFive firmware 2.1.3 dated 2014/04/02.Â
(Ifive X3-FW-442-V2.1.3_201404021720.rar /Â Ifive X3-FW-442-V2.1.3_201404021720.img)Â
Build information:
Linux Kernel:Â Linux version 3.0.36+ (five@five-server2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #68 SMP PREEMPT Wed Apr 2 16:59:31 CST 2014
Android build:Â IFive/rk3188/rk3188:4.4.2/KOT49H/eng.root.20140402.170132:eng/opinions-on-teclast-p90hdst-keys
RK3188Loader(L)_V2.09.bin
- root with latest SuperSU version 1.94 (free version)
- increased space for applications (/data partition) to 7 GB
- disabled OTA updates (may cause problems)
- added Google Experience Launcher (GEL) in addition to iFive stock launcher
- optional package to fix broken apps (Contacts/People and Calendar sync)
- included temporary fix for multi-user support, thanks to didierm
- kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma &Â Crew RKTablets, thank guys!
- optional ClockworkMod (CWM) Recovery easy install packageÂ
Download:Â kasty-fnf_ifive_x3-442-213_20140402-rooted7_mu.zip
Use Rockchip Batch Tool version 1.7 to flash the firmware, use Restore button.
If you like our work, please support us to keep the site alive and contribute to our efforts. |
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have an iFive X3 to test it.
Tiber If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2014/03/29
Hello, could you explain what the difference btw last
and this one.
And also, may be you could try to do smth with wifi signal strenght via software?
Speakers also are very silent. I tried app Volume+ on previous fw. I think it helped, but after some changes in settings it lost any effect.
Thanks a lot.
2014/02/26
I don't found any problem of custom firmware yet. I installed today.. but there are problems of official firmware.
The problem with browser is still there.. the address bar is always on, there is no history(!!!) and the browsing is not so fast and smooth like the version 4.2. I have 10.1 inch screen and I use almost 8" for browsing.. tragik! Also with other browsers (chrome and opera) the browsing is much slower!
I saw that they fixed the problem with front camera, now is right and I think the quality is little better.
For the wifi I think that also this is liiiittle better. For example on youtube app the HD videos are start to play faster. But the speedtest.net app doesn't work properly.. it show very low speed but this is not true.
For speakers I used this method and the volume is very good!!
https://www.miniand.com/wiki/Increase+your+iFive+X2's+speaker+volume+to+what+it+should+have+been+out+of+the+box
Where is the weather app from ifive? There is only the widget on lock screen but I can't found the app to change the city.
2014/02/26
With touch screen sensitivity the problem on my tablet is that is very sensitivity with this rom and when I press back some times it pressed double and it goes 2 times back.
Another one serious problem is with games! On subway surf it doesn't rotate the screen and I see the half screen in landscape mode! Also on manuganu I can't see the player!!
What do they there in ifive?!!
2014/01/24
I am having the same touchscreen problems as everyone else. The upper right part of the screen doesn't register a touch, and all along the top rim doesn't either. Certain areas are overly sensitive too. Can't get a solid touch.
I went back to 2.07 rooted rom and everything is ok.
I will try the official 2.13 rom and report back.
edit: update...
The original, untouched ROM has the problem, meaning admin, you are exonerated :D. I e-mailed iFive tech support to tell them about the problem. Maybe they will fix it.
If you want to e-mail support here are the e-mail addresses:
linct AT ifive.com.cn
dailei AT ifive.com.cn
edit #2:
Admin, in the next firmware release (which will probably be sooner than later since 2.1.3 from iFive is defective), can you add/update the following apps:
Add Google Maps
Add Google Keyboard
Update Google Play Services
Update Google Keep
Update Google Hangouts
Update Google+
Update GMail
Update any other Google services included in the ROM with the latest update at time of posting
iFive X3 | Minix Neo X5 | Samsung Galaxy S2 i777 | Samsung Galaxy S4 i337
Done, thanks for your messsage.
61 Guest(s)
Devices in use: Desktop (53), Phone (8)
