2014/01/21
could u be more specific please
If get u right u did flah device and now is not working?
I have Ifive x3 , i did exact what the topic said to restore the img .
Now the device is working with blank black screen all the time .. ( i can connect it to the computer and recongize it . )
something wrong with the display driver . since i burned this img
How can i fix it?
where can i download the offical rom (i am not able to download it from ifive offical site . the site not moving . )
Oded G
2014/01/21
Hi ,
I retired to install the ROM in this post several times and always get black screen since than
Yes please if you can download the official latest ROM for me (put it in the DROP BOX) and i will retry to install it.
I am doing the guide in the wiki so i am wondering if indeed bad IMG can cause a blank screen.
Thanks .
Oded G
Make sure you are using the Restore button when flashing in Rockchip Batch Tool.
I doubt a bad image issue would happen, as you would probably catch up an error coming when unziping the archive file, also in some cases Rockchip Batch Tool may complain when loading or flashing if the update.img has a damaged structure.
2014/01/21
when i get a green light i am flashing so the fleshing works
maybe i am doing anything wrong? can you point out the exact steps of flashing ifive x3 ,
in order to get the flashing mode to be ON , i am pressing power and volume down , and than connect the device to usb.
anything wrong with that?
you can find the link here:
https://www.dropbox.com/sh/wmrifor703yvz7w/uILWtwEGy7
dont forget, you will need to use the ifive flash tool to have it flashed properly!
i1fang said
3- Hit 'Upgrade'
We recommend to use Restore button not Upgrade for a proper firmware flashing.
2014/01/24
Just got my X3 yesterday.
Took me a while to figure out how to do it...if I had just read this page from the start, it would have saved me lots of headaches: https://www.miniand.com/wiki/Flashing+a+new+firmware+image+to+the+iFive+X3+Step+by+Step
Flashed the Kasty 4.4.2 firmware, and all is good. Only issue I have had so far was inbetween reboots (before I figured out how to flash, i.e. I was still using the stock firmware) one time my screen appeared like it was on 256 colors (think of Windows 95/98 when you changed the 24bit colors to 256 colors), but a reboot fixed that.
Like with my Minix Neo X5 (rockchip RK3066), I had issues getting my 64bit Core i7 laptop to recognize the device and accept the x64 driver in support/upgrade mode. Thankfully I have my trusty old 32bit netbook which does the job fine.
Who is Kasty and what potential is there for modding this ROM?
iFive X3 | Minix Neo X5 | Samsung Galaxy S2 i777 | Samsung Galaxy S4 i337
2014/01/24
henkjan.st said
Hi, is there a known problem that Bluetooth of the X3 doesn't see other devices?I won't recognize my phone or my Bluetooth headset!
I had no problem pairing my phone (Samsung Galaxy S4) with the X3.
82 Guest(s)
Devices in use: Desktop (71), Phone (10), Tablet (1)
makaryura
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
