2014/01/19
Hi and thanks for all your work.
This works well - wifi is excellent and it's very fast and responsive
One Q though, I have no root access, and am a bit mystified as to why?
RootcheckerPro returns this "Root access is not properly configured or was not granted"
Root Checker Adv returns this msg "You have root access, but you need to install superuser app"
SuperSU tells me "The SU binary needs to be updated. Continue ?
I tap 'continue' .. and a few seconds later 'Installation failed'
Any help will be appreciated - tnx
2014/01/20
akiva said
HiThanks Katsy
I just installed the new rom on my newly arrived ifive x2 and everything is smooth.
The only thing I am missing is the Hebrew language layout for the USB keyboard.
Did you erase not latin languages from the layout file?
Solved it with any soft keyboard app.
Everything works very good.
There is no ghosting on the screen. WIFI is still only average but this is due to the hardware.
The only thing that crashed my system was tried to boost the sound with "viper4android4x" but it seems like a problem with the specific app. Anyone know of another way to boost the volume.
2014/02/11
locutus2000 said
I finally flashed the ROM because I was stil v2.0.1 AOSP ROM and now I remember why. The stupid lockscreen with the rotating wallpapers. How to fix that? Some of these wallpapers really suck, and I can't get rid of the Shenzhen weather widget.
Security-Lock screen-none.
2013/08/09
Pepzki said
locutus2000 said
I finally flashed the ROM because I was stil v2.0.1 AOSP ROM and now I remember why. The stupid lockscreen with the rotating wallpapers. How to fix that? Some of these wallpapers really suck, and I can't get rid of the Shenzhen weather widget.Security-Lock screen-none.
But that removes the lockscreen altogether, agreed it works but it wasn't what I had in mind
2013/03/21
locutus2000 said
Pepzki said
locutus2000 said
I finally flashed the ROM because I was stil v2.0.1 AOSP ROM and now I remember why. The stupid lockscreen with the rotating wallpapers. How to fix that? Some of these wallpapers really suck, and I can't get rid of the Shenzhen weather widget.You need to Enable the widgets in Kitkat (under security) only  then you can add widgets on the lock screen and remove the chinese one !
for the background images use Xposed !
see: http://www.cultofandroid.com/45312/how-to-enable-lock-screen-widgets-in-android-4-4-kitkat-tip/
The following users say thank you to rb1213 for this useful post:
Beni2360
2013/08/09
rb1213 said
Thanks, the widgets thing worked but Xposed changes nothing unfortunately.
2014/01/20
Has anyone else gotten this error after intalling the new rom?
After installation that went OK I turned the tablet off and when I turned it on again I started getting the enoying message repedatily. I also noticed that my bottem bar is gone.
Any solution?
2014/01/20
akiva said
Has anyone else gotten this error after installing the new ROM?After installation that went OK I turned the tablet off and when I turned it on again I started getting the enoying message repeatedly. I also noticed that my bottom bar is gone.
Any solution?
I found the problem but not the solution.
The error is caused when changing the language to Hebrew. After I change the the language everything is ok but if I reboot I get the error above.
I found the exact same problem for nexus but didn't understand the solution:
http://bugs.aokp.co/issues/103
Can someone help me out?
Hello guys.
I have a question for you.
In your opinion will this ROM/image work with my CUBE U39GT.
Same CPU, RAM, 16G, Bluetooth, Full HD 9"panel.
I am considering flashing this ROM, but I am afraid that I will brick my device
Maybe it will work maybe not. The CWM recovery is compatible for this and my device.
I will be more that gratefuller if someone make CWM backup of the this rom and upload it somewhere for me to download and test it.
Thank you.
2014/03/31
First sorry for my English.
For me, this rom works very well. Thanks you.
But I have one problem :
- Settings => Users => I click under my only profile (You(Owner)) and Settings Crash.
I have test with a new profile, and it's the same bug. I can click next to my profile for change the profile's name but if i click on my profile, "Settings" crash.
2014/01/01
I finally got a nice WiFi antenna working in the X2 with better reception than the original antenna.
What I did was order a $3 replacement antenna for a Samsung Galaxy S3 on aliexpress. This has exactly the same little connector so you can directly plug it on the board.
The modification I made to this antenna was as follows. There's a little golden connector on the Samsung antenna which normally connects to something metal of the S3 body. What I did was solder a little piece of 1 mm thick sheet-copper to this connector, but made sure it would still fit where the original antenna is placed.
The reception still isn't as good as with most smartphones and somehow the upload speed is higher than the download speed, but that might be a ROM issue as well, I'm not sure.
The following users say thank you to FlowDesign for this useful post:
sbr.harryMost Users Ever Online: 749
61 Guest(s)
Devices in use: Desktop (56), Phone (4), Tablet (1)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
