2013/12/29
I'm having problems with flash player and dolphin browser it seems it plays less videos unlike when I was on 4.2.2 when it would virtually play any YouTube videos I choose. Also some apps that used to work then does not now, like montano reader premium, flappy bird is kinda laggy and has minor graphics problem. The good thing though is that there are no more graphics problems.
2013/10/06
vabiris said
do you have any problems with app shortcuts on home screen? some shortcuts disappeared. This seems to happen with apps that are moved to nand flash.
First of all I have had no issues so far, everything looks good.
Secondly, vabiris - I believe this is an issue with the official firmware also, not just the custom firmware. I have the same issue and have not moved any apps. I use kcin launcher with a custom app grid size, and it's always the same two icons that go missing from my home screen - top right and two below that, even though I have a spare column to the right of these.
Thirdly, yaniv050 - damn you're rude! Who the hell do you think you are? You're hardly likely to get a helpful response talking like that!
Thanks again Admin, great job
FNF iFive X2 (Kasty 4.4.2 KitKat ROM)
2014/02/11
Pepzki said
Hdmi working with this rom? Can i use ManuRoms OC Kernel with this rom? Thank you!
Both works!
2014/02/17
Thirdly, yaniv050 - damn you're rude! Who the hell do you think you are? You're hardly likely to get a helpful response talking like that!Â
I'm sorry I just wanted to press to get the version of cwm, but in the end I installed using the computer and all is well. Thanks for the hard work. Everything works smoothly, just Galil online not one hundred percent smoothly. There is a way to fix it
Thanks again
64 Guest(s)
Devices in use: Desktop (58), Phone (5), Tablet (1)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
